'52 Chevy 3600: Picking a rear-end - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2010, 07:31 AM
I have a 52 Chevy 3600 p/u I'm working on and I put a wanted ad on the local website for a rear end. I asked for a 60" wide rear end from certain years of Novas, Chevelles, and Camaros (I listed the applicable years) and here is what I got as a response:
*yes I have a 64-67 ratio is 3:07 I think Chevelle 5 x 4.75. ratios are 2:73 and 3:08 and a few 68-72 10 bolt chevelle, I also have a 68-72 12 bolt posi 3:73.*
I would like some input on which I should chose. They all should be 5x4.75' and it will be behind a 292 L6 and a Saginaw 4 spd (most likely). My first inkling was to go with the 12 bolt posi but I'm not sure. Can someone with a little bit more knowledge help me in the right direction? This is my first build and it's going to be used as a driver/cruiser with grunt (probably won't take it over 80 mph). BTW he only wants $75 each. Thanks in advance.
-Greg
Old 10-06-2010, 08:15 AM
big gear head's Avatar
High Performance Rear Ends
The '64 to '67 Chevelle rear end is 60 inches wide. The '64 has different splines on the axles, so you might want to go with '65 to '67. You don't need the 12 bolt with a I6 engine.
Old 10-06-2010, 10:07 AM
Wiki Edits: 49
You don't need to go with anything larger than a 10 bolt with an inline 6. This truck has a '78 Firebird 10 bolt, 3.08 posi rear in it that I picked up at a swap meet for $100 and it sits behind a Chrysler hemi. Fits perfectly and is a 4.75 bolt pattern.
Old 10-06-2010, 11:29 AM
Thank you for your help. I'm going to give the guy a call tonight so I can get this rear end started. Now to find a rear end conversion kit.
-Greg
Old 10-06-2010, 02:12 PM
oldtimercarnut's Avatar
Crakums_GT
Hi I don't know how far you are from me but I am looking for a 12 bolt posi 3:73 for my 1967 Camaro. Is there any way that I can see the add for the 3:73 so I can give them a call if close enough. Thanks and good luck with your build.
Old 10-07-2010, 07:41 AM
That rear end is not in an ad. It was actually in a reply to my "WANTED" ad. He is located here in North Dakota though.
-Greg
Old 10-07-2010, 08:40 AM
Thanks for the reply Graig. I think North Dakota is just a little far from Pittsburgh Pa. Take care and keep building. Chuck
Old 10-07-2010, 09:15 AM
No problem. I hope you're able to find what you need.
-Greg
52 Chevy 3600, 76 Nova rear flip axle Crakums_GT Transmission - Rearend 10 07-30-2010 09:38 AM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
62 chevy pickup rear end carrier into Bel Air Tymer Transmission - Rearend 1 07-30-2008 09:14 PM
1941 Chevy transmission and rear end lubricant. CrashFarmer2 Transmission - Rearend 2 06-30-2008 06:17 AM
Chevy rear end swap Truplayainfla Introduce Yourself 1 10-23-2004 11:07 PM
