52 chevy on 96 caprice - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2008, 05:56 PM
I'd like to drop my 52 chevy 2 door onto a 96 chevy caprice frame. the wheel base on the 52 is 118 the width is 66" not exact,my measurements.
I can't find anything on the caprice measurements. any suggestions before I bite off more then I can chew? anyone have aexact measurements for these two?
Old 09-03-2008, 06:18 PM
Wiki Edits: 31
'49-'52 Chevy is 115" wheelbase
'91-'96 Impala is 115.9" and the overall width is 77"
my thinking is that it is too wide.... IMO, frame swaps on '49-54 Chevy's are not all that common.. you can put a clip on your front end, and put a 4 link on the rear using the stock frame, easier than you would be trying to make the body fit a frame, that is likely too big
Old 09-05-2008, 05:11 AM
techinspector1's Avatar
Wiki Edits: 326
I agree with Matt, but would take it a step further and use the Caprice front and rear clips welded to the early Chevy center section where it bolts to the body 1/3, 1/3, 1/3. That way, you can set the body at the exact ride height and attitude you want to end up at without using goofy cut springs, lowered spindles or any of the other stupid stuff guys do to cars. Stock Caprice suspension, brakes and steering. What a concept!!!!
Front clip / subframe for '52 Chevy Truck dcostellow Suspension - Brakes - Steering 10 05-09-2014 10:29 AM
P.S. & suspension tips for a 52 Chevy? panamracer Suspension - Brakes - Steering 5 04-20-2010 09:35 PM
52 Chevy Pick-UP Door Hinges Blaster Body - Exterior 5 07-29-2006 11:47 AM
another 52 chevy rustyoldcars Suspension - Brakes - Steering 2 10-08-2005 02:33 PM
52' chevy pickup cheebs_01 Engine 4 04-14-2003 10:42 PM
