52 chevy coupe Disc Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2009, 03:02 PM
Last journal entry: Squirrels...
Anybody have any info on doing a swap for the front? Is there anything compatible? I'm sure fabricating a bracket or two will be involved, but I want to know who's done it already.
My first thought was to replace the entire frame with an s10...decided against it. Then thought about a CE MII IFS set up...but that's too expensive and requires cutting the inner fender walls....so now I'm going to rebuild the stock front and replace the motor,tranny and stock drums up front with discs. I just don't know if I should get a kit or steal some from another car/truck. Any help or advice is useful and appreciated.
Old 04-04-2009, 08:58 AM
Wiki Edits: 27
try speedway
speedway motors has a kit uo use chevy spindles on ford beam axles the spindles have to be machined... talk to them.. I don't know about interference also scarebird does a lot of disc conversions
Willys Planar Front Suspension disc brakes? Stark Miller Suspension - Brakes - Steering 7 02-12-2012 10:00 AM
58 chevy belair 4 wheel disc brakes change over Rick England General Rodding Tech 1 02-22-2006 09:40 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
63 sub disc brakes or no disc brakes sub63 Suspension - Brakes - Steering 5 03-19-2005 11:31 PM
What engine in a '52 Chevy Coupe product Engine 3 09-20-2004 05:32 PM
