52 Chevy Pick-up Inside Door Molding - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2006, 07:01 PM
Where can I get this? This is the inside rubber molding that fit's into the c-channel along the inside of the cab that outline's the door area's. I have looked at Chevy Duty, LMC and Jim Carter's. Any help would be appreciated!
Thanks'
Blaster
Old 02-28-2006, 07:13 PM
Wiki Edits: 49
Any number of early Chevy truck suppliers.
Chevy Duty has this item Part #03-106 for under $20. Look under 47-54 parts and select door weather strip.
Old 03-01-2006, 11:07 AM
What you are looking for is the windlace. All truck suppliers sell it in many different colors.
Old 03-01-2006, 10:34 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Hey, Blaster
Chevy Duty is the most reliable in terms of getting the best fitting parts for your truck. LMC is probably the worst -- for example, I put new door rubber on my truck 3 times before I got rubber that was the right fit. First time was LMC Truck and the rubber was so thick I, literally, could not close my doors without slamming them with totally unbelievable force. Second time I took it to a pro' and the reverse happened -- the rubber was so thin, my doors wouldn't stop rattling. Finally, after I learned about Chevy Duty, I did the job myself with perfect results.
Check out my site link below my sig and scroll down ... you'll see every project I've done on my truck, with photo tutorials ... and at the bottom of the page, links to all the cool catalogs and truck discussion boards.
All the best to you, bro'!
Alan Horvath
54 Chevy Pickup
454bbc with t 400 trans 19471/2ton chevy pick up timbro 42 Engine 8 03-11-2009 07:03 PM
Which Spring Kit to use on 52 Chevy Truck Rick.Coleman Suspension - Brakes - Steering 1 11-08-2005 05:02 PM
where to pick up new front floor pan for a 47 chevy sedan? rat-lac Body - Exterior 4 11-07-2005 06:58 AM
52' chevy pickup cheebs_01 Engine 4 04-14-2003 09:42 PM
1955 Chevy Pick Up, Wheel rear spacing? Alf Transmission - Rearend 1 09-19-2002 07:02 PM
