-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   52 chevy truck (http://www.hotrodders.com/forum/52-chevy-truck-226590.html)
fy54957 11-27-2012 08:41 PM
52 chevy truck
What kind of seats will work the best---
MARTINSR 11-27-2012 09:47 PM
Realistically you need to remove the seat riser, that is one problem with these trucks if you want to change the seat. The cushions mount on the seat frame which is bolted to the riser that is welded to the floor. You could mount something somehow to the seat riser I have seen that. But when I changed the seats in my truck I removed the seat riser and simply bolted the seat in like any other car.
herman quail 11-28-2012 06:00 AM
I also took out the bench seat and riser out of my 53 chevy truck. I put in mustang fox body seats.
Something to think about, If you remove the riser you will have to stiffen the floor of the cab. I added two pieces of channel to stiffen the floor. Then I made a frame to hold the seats at the height I liked.
steve
DanTwoLakes 11-28-2012 08:53 AM
All good advice from Brian and Herman. The problem with the older trucks is that the cabs are narrow. If you want to use a bench seat, you'll need one out of a compact pickup like a Ranger, Dakota, or S-10. Or, a middle seat out of a Chrysler mini van.
MARTINSR 11-28-2012 09:09 AM
Yeah, in my case the top was chopped and the steering column shortened so I bolted the 65 Tempest bucket seats right to the floor. It did get a little support with a flat stock going across from side to side as I remember but that was it. The buckets could be a little closer together so the width wasn't an issue.
It's not narrow enough to need the mini van center seat that would be too narrow, but good thinking, that is a perfect seat for a little earlier truck or car.
joe_padavano 11-28-2012 03:12 PM
The Dakota seats are popular in the 48-54 AD trucks.
fy54957 11-30-2012 05:03 AM
Thank's for all the help----It's a 52 truck it has a 54 cab on it. The floor is all flat now we have put a pieces of steel in the floor.Just re wired the truck,and hope to put engine in 12-1-2012-SBC 406 try to get some pictures are here soon has I can :thumbup:
496CHEVY3100 12-05-2012 10:29 PM
I have a 53 i used 2002 camry seats i used a center console fits great,two of my freinds also have AD trucks one 50 used rear seat from a surburban Leather with center fold down armreast and cup holders it has flat floor the other 52 used 90 silverado perfect width does not touch doors heighy is correct,looks great ,ofered in leather or fabric,wide choice of colors if you dont want to recover
fy54957 12-16-2012 08:12 PM
Thank's for all the help just put engine in and got it running on the way to muffier shop monday I hope
fy54957 03-30-2014 08:18 PM
Still looking seats ,and trying see what we like.:confused: Trucks in Body shop we getting it ready for a new coat of Black paint.:thumbup:
496CHEVY3100 03-30-2014 09:01 PM
4 Attachment(s)
Just a couple of ideas,Not saying this is what you should use just a couple of examples I used I removed the Lt Gray interior I had Camry seats and console
The first set in these photos is from a 2008 Bmw 535 they fit the best for me because if the risers I built in the floor the height and with are Ideal for an AD cab
the second photo is from an infinity Q35 a little narrow in sholders
the third set is from from a Lexus a little to wide in seat area my console would not clear.
The last photo shows the riser built in floor my air cond vent tubes will run inside console beside the shifter through the riser and exit behind the seat thru a set of 71 Chevy Cheyenne pu air cond vents turned vertical on each corner behind seats ,
don't know how that will look but after ibstalled it will be to late ,I will have to learn to like it :D:D
post some photos along,
CraigK 03-30-2014 09:50 PM
On my 53 I plan on chopping my springs out and using foam in place of the springs. I just have to find a chunk of foam, I have no idea what kind of foam.
I have a rear seat from a 95 Safari that would go in there almost perfect.
John long 03-30-2014 10:32 PM
Do a search for seat foam on the forum Craig. DanTwoLakes has done several posts concerning foam. How it is labeled, what density to use in what application, etc. There are good answers at the tips of your fingers on that one.
John
DanTwoLakes 03-31-2014 08:57 AM
Why are you "chopping your springs out"? With the springs out, there is no give to the foam. If you don't use a thick enough or firm enough piece of foam, you will bottom the foam out and basically be sitting on what's under it. Think twice before you do anything.
Dragonoake 04-01-2014 09:43 PM
I really like the way these look
