52 chevy truck , change the rear end in it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2010, 09:34 PM
I have a 52 chevy truck and I'd like to change rear end gears for interstate driving with out changing the complete rear end. Is this possible? My truck has a 54 235 engine.
Thank You
Old 01-01-2011, 12:09 AM
big gear head's Avatar
High Performance Rear Ends
I don't think there are any good gears for that rear end. I think you are going to have to install a newer rear end to get the gear ratio that you want. First gen Camaro and '68 and later Nova rear ends are popular swaps, and plenty strong for your engine.
Old 01-01-2011, 01:34 AM
Wiki Edits: 31
4.11 and 3.55 were available in those, but thats still pretty tall. is it still got the torque tube?
Old 01-01-2011, 07:37 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Look up Patricks antique auto parts in Casa Grande AZ
or clik here
Patrick had some 3.55 gears for the torque tube differential some years back. Check with them to see if they still do
Old 01-01-2011, 08:24 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
can you put taller tires on the back?
47 Chevy Coupe Rear End Change ? bluesman2333 Transmission - Rearend 12 06-24-2008 03:47 PM
chevy truck spring change Jmark Suspension - Brakes - Steering 3 02-04-2008 04:15 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
82 Chevy Truck change to small pattern musky2 Suspension - Brakes - Steering 11 01-09-2004 08:56 PM
69 chevy truck front end change dragn azz Suspension - Brakes - Steering 4 07-23-2003 01:16 AM
