Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 52 Chevy truck ...Hurry!
Old 02-17-2002, 09:11 AM
freddy4speed freddy4speed is offline
Sorry I was unclear...the front end is from a 52 Chevy truck, discarded because the owner states he wanted to go to discs, so he went ifs. It's the standard Chev parallel leaf front w stock spindles...everything looks new, no pitting,the springs, kingpins are tight, spindle threads good, axle straight, new u-bolts, has the stamped factory front mounting brackets and shock mounting brackets, springs 28 in side to side, axle 50.5 in center to center; cleaned up and painted for 150.00 but I know I can do better....I plan to use as front suspension on gasser coupe chassis with cross steering, sb Chev...engineered components looks like a good bet...thanks...
