52 Chevy Truck Rim Sizes?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2011, 11:39 PM
I have been looking all over to see what people are running on these but havent found much information. I have a Heidts Mustang II with 2 inch drop spindles. I read somewhere you have to run 17" or larger wheels to clear everything with the 2" drop spindles, is this true? I planned on running 18s up front anyway but also considering some 15 steelies sometime. On the rear end I have a 8.8 Ford explorer. I want to put 20s on the back, 8 inches wide. I did some quick calculatons and figured a 20x8 with 3 inch backspacing should fit. i cannot find any decent rims in that size, or am I just not looking hard enough? Any help would be greatly appreciated! Thanks
Old 04-30-2011, 01:11 PM
35terraplane's Avatar
52 chevy truck
I have a 33 ford with 2" dropped spindles, and Mustang Road racing springs that lower it another 1 1/2" I couldn't get 17" wheels on it if I wanted. On the P/U you should have a lot of room in that fender, it's how close to the fender is the wheel and tire so you can turn, how much of the fender is going to be over the tire. you have to know what size tire you will run, half of the total will be below the spindle, half above, as long as you don't hit the fender with the outer edge of the tire, or hit it when you turn your fine there. then you just make sure when the tire goes up and down you don't hit the top of the fender, but I don't see that happening.
Old 04-30-2011, 04:21 PM
Wiki Edits: 49
My '53 AD truck. Mustang II IFS, standard spindles, big GM 11" disks and stock 1969 Camaro Rally wheels. I can't imagine how low it would sit with 2" dropped spindles.
Centerline
HotRodsAndHemis.com
"If you can leave two black stripes from the exit of one corner to the braking zone of the next, you have enough horsepower." Mark Donohue
Old 04-30-2011, 06:31 PM
52 chev
Centerline
HotRodsAndHemis.com
"If you can leave two black stripes from the exit of one corner to the braking zone of the next, you have enough horsepower." � Mark Donohue
I would think about 2".
Bob
Rim sizes for 52 Chevy truck??? j_johnson Suspension - Brakes - Steering 1 02-21-2011 12:51 PM
Engine bolt sizes for 350 chevy eric32 Engine 6 05-02-2009 08:05 PM
55 chevy rim sizes$ frankxlara General Rodding Tech 4 07-16-2005 08:11 PM
chevy truck sizes chevcamz28newbie General Rodding Tech 3 08-23-2003 02:40 PM
tire sizes for my truck jniolon Body - Exterior 1 07-19-2002 08:58 AM
