52 chevy truck window question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2009, 12:56 AM
the doors on my truck have wing windows, and i want solid windows like the older trucks. can i convert my doors to accept one piece door glass?
Old 08-14-2009, 01:21 AM
life is a temporary assignment
Yes you can..They sell kit's to do it..
Old 08-14-2009, 10:20 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Randy's right, here is a great place to look: CLICK HERE
Old 08-16-2009, 02:18 AM
i'm not sure if i want power windows. so im looking to see if any one has installed older door hardware in the newer doors, hardware meaning regulators and window tracks? i dont feel i need to spend 600 bucks to make my windows roll down, it doesn't seem like a good way to spend money
Old 08-25-2009, 12:34 AM
is there anymore input on this?
Old 09-16-2009, 01:22 AM
ema ema is offline
New Member
You can try searching for replacements at this chevy truck interior parts dealer site. There, I hope you succeed in the modifications.
Old 09-16-2009, 02:51 AM
buggmann's Avatar
build it like you like them
Last journal entry: buggmann stilling looking
Wiki Edits: 2
buggmann
look on www.lmctruck.com i got a lot of parts
for my 52 chevy truck when i had it
Old 09-23-2009, 12:27 AM
new_rat:
It is possible to do it, I did it on my truck, but it isn't easy...
The 47 to 50 1pc windows have a frame around the glass, where as the 51 to 55 door glass is frame-less. Thus the felt channels are thinner on the later design, and the interior window trim piece is "thicker" to compensate. I didn't look at early doors to compare, but the upper frame of the door likely has a different profile to suit the thicker window felt channel.
What I did was remove the vent window stuff, fit AutoLoc flat glass power windows and formed and mounted bulk felt channel in the door. The one area that I didn't address was the exterior glass wiper that is internal to the door - it is still short.. That short sentence represents a week of evenings for the first door - the second was done in about four hours.
There is very limited room to work inside the doors, so be sure to buy a box of band-aids.
For mounting the felt track at the front of the door, I salvaged the rear felt mounting track out of some junk doors that I had.
I used the early glass, but it is barely tall enough - a custom cut piece would make the power window install easier.
HTHs
Jim
Old 09-23-2009, 12:50 AM
countryboytn's Avatar
you can never know to much
Last wiki edit: Practice page Last photo:
Wiki Edits: 3
I don't see why you couldn't switch out doors from a earlier model? If they fit, It might be cheaper, and easier.
(I'm not 100% sure they would, but I don't see why they wouldn't)
Old 09-23-2009, 09:42 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
Here is an article from a past Custom Classic Truck issue on the subject.
http://www.customclassictrucks.com/t...ion/index.html
There are no off the shelf kits for this. Keep the vent.
Chevy AD truck steering column question mr52pickup Suspension - Brakes - Steering 1 10-24-2008 07:45 PM
52 chevy window 52 car guy Hotrodding Basics 1 08-21-2006 07:20 AM
Question on 49 chevy truck frame sevt_chevelle Body - Exterior 4 08-13-2006 02:42 PM
Side window options for a 41 chevy truck? badriand Interior 4 09-15-2005 09:26 PM
Chevy Vortec 350 Truck question 79 Malibu327 Engine 3 07-08-2004 11:41 PM
