52 ford f100 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2004, 02:56 PM
flathedflynn's Avatar
52 ford f100
i want to replace the rear end in my 52 ford f100.any advise on what kind of rear end would work and what kind of problems might i run into?
Old 10-13-2004, 04:03 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Ford rear end
I would take the measurements of the existing rear..distance between the spring perches..over all length of the rear end..and then go off to my friendly local wrecking yards in search of a rear end from a late ford.. find one with a 9"
Just the ususal hardship here..get the pinion angle right and the new one centered and square in the chassis so we do not have a dog walker..might even find one that has the same bolt pattern on the wheels so that does not need changing..
Probably will need some new spring perches welded on..I don't seem to get that lucky to find one tha tis a straight bolt in deal..might have to do something with the shock mounts as well..those never seem to be in the right spot..
Most of the guys I know in the yards are pretty helpful and if they are not go somewhere else..
This is one of the swaps that is really straight forward..and I am assuming this thing is a half ton truck..
Old 10-13-2004, 04:20 PM
poncho62's Avatar
Wiki Edits: 5
I've had a 76 Nova and a 57 Chevy rear ends in my 51. Had to change spring perch locations in both cases, but its not that big a deal.
Old 10-13-2004, 07:50 PM
the rear axle from a '57 - 72 f100 will bolt right in. It is a ford 9", same width on the spring perches, same wheel bolt pattern 5 on 5-1/2". plus they are pretty easy to come by.
Gary
Old 10-14-2004, 01:00 PM
vintage56's Avatar
New Member
Last journal entry: and this should be it...for now
what about the '53-'56?
Gary,
you mentioned the '57 thru ??? What about the '53-'56? Is the distance different between the springs?
Old 10-14-2004, 01:53 PM
the axles from 1957 to 1972 F100's are all Ford 9" rear ends, these are super easy to get anything for(replacement parts, disk brake kits, different 3rd members with better gears and limited slips can be found at a junkyard). I imagine the axles from 53 - 56 would work but I would prefer the 9".
Gary
Did you mean, will the newer axles fit into a 53 -56? YES. same srping perch width.
Gary
Old 10-16-2004, 10:38 AM
52 ford f100
thanks for all the info guys,its greatly appreciated.
