52 Pontiac Chieftan 2 door post
Hi. Have a 52 Pontiac Chieftan 2 door post and would like to change the front suspension.Nothing fancy. Would I be better off to use a Mustang II system or try using a S-10 frame? Plan on putting a chev 350 with a 700R4 into it, along with a rear end from a S-10. Would appreciate any comments.
I tend to agree with "streetrod," but I realize parts availability might be a problem. Also, there are probably no dropped spindles available and, finally, the ball joints allow you to gain some braking anti-dive. It seems, however, that you're considering a full frame swap, which seems to be more than you need. I'd consider just a Camaro front clip. This would give you the opportunity to lower the car a bit and, with plates and gusseting, is a fairly simple task.
At the rear, I'd suggest something like Art Morrison's 4bar package or a fabricated equivalent with a Panhard. This is an easy conversion and, if you angle the right side up more than the left, you can even have some dynamic canceling of the driveshaft torque. I probably wouldn't have looked at this thread, but it caught my eye because my first car was a '52 Pontiac Super Deluxe Catalina. Two tone green with a leather interior. Pontiac (and Chevy) introduced some fancy colors and interiors that year. |
I don't think I would go with a Mustang II IFS in a '50s car which is surprising for me cause I like the Mustang IFS on most street rods. The problem with the '50s cars is their weight. Although the Mustang IFS can handle the weight of most street rods with no problems when you get into the '50s cars got bigger and a great deal heavier.
I believe the easiest solution in this case would be a Camaro clip. They're plentiful, have disk brakes and SBC mounts and are fairly easy to install as clips go. |
| Pontiac 400 vs. Pontiac 455 | chevyelc81 | Engine | 7 | 03-19-2011 07:31 PM |
| what's up with pontiac engines (or BOPs) | bullheimer | Engine | 15 | 09-11-2009 09:57 PM |
| disk brake swap on 52 pontiac?? | suede | Suspension - Brakes - Steering | 6 | 07-23-2007 06:27 AM |
| 34 pontiac 81 camaro subframe install ? | mobythevan | Suspension - Brakes - Steering | 7 | 05-19-2005 12:17 PM |
| Pontiac | xxx(madmax )xxx | Engine | 13 | 12-05-2002 07:03 PM |
