'53-239 Flathead V8 sluggish - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2008, 08:22 AM
It seems the more I adjust things the worst the car runs! I've changed out the economizer in the carb but still runs sluggish. on acceleration the car shutters and sputters...I put new points in set the gap at .15, is that to little? I'm going to change out the intake manifold gasket today...as for sure I have leaks...My hopes its the cause of some issues. I live in Central Oregon...do any of you know anyone in the area that is familier with Flatties?
Old 06-19-2008, 11:01 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
The points are correct at .015
FO15486372
dwell 28-32
PG .030
compression 110min
get back to us after the gasket change.
Good luck,
Rich
Flathead V8 ?'s " for school project" 51FordDuff General Rodding Tech 4 06-12-2009 03:55 PM
wiring diagram for 53' ford flathead v8 customline? onewheeltirefyer Electrical 1 06-25-2008 10:33 AM
53 flathead v8 wire diagram onewheeltirefyer Electrical 1 06-01-2008 07:21 PM
239 Flathead V8 51Ford Engine 2 07-11-2006 11:23 AM
239 cu inch flathead v8 flathedflynn Transmission - Rearend 7 07-05-2006 01:47 PM
