53 and 56 trans/engine ?'s - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2013, 12:45 PM
Will a 56 model powerglide (originally on a 235 open driveshaft car) bolt up to a 53 model 6 cyl (originally power glide closed torque tube type) bolt up to the 53 model motor without any issues? I have a really good 56 model glide that I'd like to take advantage of. I'm fairly sure I can get a rear end to put in my 53 out of the 56 as well, leaving just having a shaft made (unless the one from the 56 happened to be correct length) hope that made sense.
Todd in South Carolina
Old 10-21-2013, 09:03 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Trans should bolt to the engine.
This what I have found on most GM torque tube setups:
the rear leaf springs for the torque tube setup are different from non-torque tube springs. The bolt that locates the differential pad is father forward near 2 inches on the torque tube setup.
You bolt in a regular open differential in place of a torque tube and the wheel center line is a couple inches forward in the fender opening
Old 10-22-2013, 05:23 AM
I read on one forum a while back, take the leaf springs and flip them around and to the other side gets the center closer. ???
Old 10-22-2013, 07:57 AM
I believe you can leave the springs alone and just re-drill the axle's spring pad to center the axle. It is commonly done when swapping in a tri 5 axle.
John
Old 10-23-2013, 11:59 AM
sounds good. just weighing out my options
New Engine and Trans jeffmc Engine 2 05-27-2013 09:34 PM
4L60e trans 4.3 to 5.7 engine? barry107 Transmission - Rearend 5 11-25-2011 10:47 AM
engine,trans,id nomac Engine 4 02-04-2008 01:55 PM
engine and trans swap 32wizard Engine 1 03-28-2007 05:16 PM
Need new engine and trans. toeme Hotrodding Basics 7 12-22-2005 12:48 AM
