53 Belair conv rust repair - Page 22 - Hot Rod Forum : Hotrodders Bulletin Board
  #316 (permalink)
Old 08-05-2013, 07:40 PM
Today was the day I was going to install the drivers side toe board but that is not how it worked out. I hot wrenched the bolt out for the accelerator pedal and here is what I found.
Not a big deal but another 2-3 hours fooling with a little patch that doesn't really amount to much. It is ready to tack in but I had to make a decision.....Go ahead and tack it in or take a shower and drive the roadster over to the cruise in at the Sonic. Yea, the shower felt good.
John
The Following 3 Users Say Thank You to John long For This Useful Post:
Jeanalvitre (01-14-2015), MARTINSR (08-07-2014), pm5471 (01-09-2015)
  #317 (permalink)
Old 08-05-2013, 07:46 PM
1971BB427's Avatar
That was an easy decision to make! Shower and cruise is a nice way to end a day's work!
  #318 (permalink)
Old 08-05-2013, 11:26 PM
Yesterday I did just the opposite. I was all ready to go to a show with the Gran Sport and decided not to and got a little done. But damn it's hard, relaxing is really what we should be doing but I had Saturday so I went ahead and put a little time in on the truck.
It's looking good John!
  #319 (permalink)
Old 08-06-2013, 10:05 PM
Originally Posted by Lizer View Post
John have you seen Eastwood's new little bench top English wheel?
English Wheel - How To Make a Fender Flare & Techniques - Eastwood - YouTube
Josh, take a look at this. It comes with free shipping and a full set of lower anvils.
English Wheel 22" Throat Depth Sheet Metal Planishing Anvil Shrinker Shaping | eBay
The Following User Says Thank You to John long For This Useful Post:
  #320 (permalink)
Old 08-06-2013, 10:12 PM
Damn that's a sweet deal John, I paid almost that much for the piece of garbage I have, wow.
  #321 (permalink)
Old 08-10-2013, 08:21 PM
Got back to the shop for a very short time this evening. The three pieces that make up the front corner of the drivers side floorboard and body mount are now one assembly.
I plug welded everything together to hide the welds.
You can see how much this will look like they are spot welded when the car is painted.
This assembly is almost ready to weld in but still needs to be tweaked a bit to fit correctly. I don't think it is going to be a big deal though.
  #322 (permalink)
Old 08-10-2013, 08:49 PM
Faith - Respect - Trust
John, you need to take back what you said about not getting much done...compared to me, well I laid two more coats of primmer in a hood...took me almost 6 hours...LOL. Well at least I gave plenty of flash time. That's what happens when you watch TV, answer a few PM's and answer a few questions on the forum. I like watching early morning TV on Saturday, even though it was repeats and not very motivational...I'm a sucker for old TV Series Westerns, two of my favorite episodes and well there's your flash time...LOL
Things you did today was again, amazing...I'm sure anyone that will see your Chevy when your done John, no one will ever know it had any rust repair, your quality speaks for itself.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
John long (08-10-2013)
  #323 (permalink)
Old 08-11-2013, 09:42 AM
deadbodyman's Avatar
Wiki Edits: 11
STILL NO PRIMER?????LOL......
John your at a point where I might be able to save you some time and money..If you already know this then disregaurd...
I noticed you used a weld thru primer on the inside of your mount before welding ,well it looks like weld thru but That stuff is super expensive and you'll need a lot of it so when I need a weld thru primer I use cold galvivizing compound from krylon you can get it for around 6.00 a can and its a BIG can insted of paying about 20.00 a can..One of the bodymen I hired told me it was the same stuff and to get some and try it (in one ear and out the other)
well...he brought some of his own in and showed me and I couldnt believe it.it works good.
.ok, theres the saving money part and this may save you some time and agravation...
When I did this on my car, which wasnt a vert, btw... my cowl had dropped when it did of coarese the front A pillars spread apart a bit and the B pillars spread also spread out from each other alsonot onlt That the A& B pillar on both sides spread ,requiring me to pull them closer together. When I shut the door to ckeck the gaps the bottom of the door stuck out about a 1/2" with everything adjusted as far in as possable and about a 1/2" gap at the bottom,I was half expecting this so I had used drill screws to hold everythig in place...I had to jack up the cowl to get the door aligned what saved a lot of time is all I had to do was remove a couple screws, jack it up and in ;and tweak it and put the screws in they're new posistion and try the fit again.I see a lot of guys skip this check and weld as they go only to find out it was off a bit and have to take all the welds out and do it over or worse live with it. drill screws are a life saver.... I just thought I'd bring that up, if not for you then someone thats doing something similar....
The Following User Says Thank You to deadbodyman For This Useful Post:
pm5471 (01-09-2015)
  #324 (permalink)
Old 08-11-2013, 12:17 PM
Both suggestions are excellent Mike. Thanks for sharing. You are correct about the weld-thru primer. I really wanted to prime the inner pieces with Epoxy but there are just so many things you could do. The line has to be drawn somewhere. I believe the cold galvanizing compound might be the perfect compromize. Thanks again.
One of the advantages a convertible has is the front is not attached to the rear so I can raise or lower the cowl without effecting the rear body shell. I do wish I had temp screwed the toe board patch to this assembly. Once I had just where I wanted it I could have tack welded it, taken it back out, permenantly welded and installed it. Again your suggestion would have worked for me. down the road, as the project continues I will do that.
Ain't this site cool?
John
The Following 2 Users Say Thank You to John long For This Useful Post:
  #325 (permalink)
Old 08-11-2013, 05:33 PM
1971BB427's Avatar
[QUOTE=deadbodyman;1703830]STILL NO PRIMER?????LOL......
well...he brought some of his own in and showed me and I couldnt believe it.it works good.[QUOTE]
No concerns about galvanize poisoning with the spray on stuff when welding?
  #326 (permalink)
Old 08-11-2013, 06:08 PM
[quote=1971BB427;1704004]
I noticed you used a weld thru primer on the inside of your mount before welding ,well it looks like weld thru but That stuff is super expensive and you'll need a lot of it so when I need a weld thru primer I use cold galvivizing compound from krylon.....
Good question, Do you know what precautions need to be taken Mike?
I welded my front corner in today. Now you can see how it fits together.
Before
After
Here is a picture of the assembly welded in place,
To finish installing it I need to gently heat the top support around the edges with my O/A torch. Once it is cherry red It will be soft enough to gently tap it down to provide a tight fit with the floor pan. When that is welded around the outer and inner circumferance this mount should be as strong as it ever was.
John
  #327 (permalink)
Old 08-11-2013, 06:23 PM
1971BB427's Avatar
When I'm welding around metal that's galvanized I stage a fan close by to blow fumes away. I try not to have it blowing directly on my weld, as it tends to blow the gas away. Just blowing close by, so it pulls the smoke and galvanizing gas away from me, so I wont breathe it in.
  #328 (permalink)
Old 08-11-2013, 06:27 PM
It's really starting to take shape John. I can sure see that there's a lot thought going into this project. I just went through a lot of the pictures and posts...it's an amazing transformation happening in real time. Now this is a reality show I could watch all day long...and the reruns would just be great refresher courses.
Ray
John long (08-11-2013)
  #329 (permalink)
Old 08-11-2013, 06:36 PM
1971BB427's Avatar
Ray
It would never get on TV! No screaming, name calling, throwing things, or swearing! At least that we know of!
  #330 (permalink)
Old 08-11-2013, 06:40 PM
Your right...but this would be the first real reality TV show...LOL
Ray
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
rust repair blackchevy3de Body - Exterior 0 06-22-2010 07:15 PM
What to do for this rust repair? chevymike Body - Exterior 5 06-04-2010 06:49 AM
Rust repair help mydixie Body - Exterior 3 02-22-2006 08:07 PM
rust repair fennerford Body - Exterior 3 12-28-2004 05:30 PM
Rust Repair gguertin145 Body - Exterior 5 11-27-2003 08:02 AM
