53 Belair conv rust repair - Page 23 - Hot Rod Forum : Hotrodders Bulletin Board
  #331 (permalink)
Old 08-11-2013, 07:32 PM
LOL. It would be B rated for boring.
The Following User Says Thank You to John long For This Useful Post:
MARTINSR (08-07-2014)
  #332 (permalink)
Old 08-11-2013, 08:00 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
John we .,You need to change name from Rusty to Mona lisa ,that will be a work of art when completed ..
Be extremely careful when using galvanizing compound fumes will go upstairs,,
that is as sick as I have ever been ,welded a galvanized axle for a friend ,,Bad Bad
of course you already know this.
The Following User Says Thank You to 496CHEVY3100 For This Useful Post:
John long (08-11-2013)
  #333 (permalink)
Old 08-11-2013, 10:32 PM
Originally Posted by 1971BB427 View Post
When I'm welding around metal that's galvanized I stage a fan close by to blow fumes away. I try not to have it blowing directly on my weld, as it tends to blow the gas away. Just blowing close by, so it pulls the smoke and galvanizing gas away from me, so I wont breathe it in.
A welding respirator is really needed when welding thru "weld thru primer", it is full of zinc (upwards of 95%) and is very dangerous. A fan is a big help but a respirator is also needed.
The Following User Says Thank You to MARTINSR For This Useful Post:
1GH (11-29-2013)
  #334 (permalink)
Old 08-11-2013, 10:33 PM
[quote=John long;1704012]
Good question, Do you know what precautions need to be taken Mike?
I welded my front corner in today. Now you can see how it fits together.
Before
After
Here is a picture of the assembly welded in place,
To finish installing it I need to gently heat the top support around the edges with my O/A torch. Once it is cherry red It will be soft enough to gently tap it down to provide a tight fit with the floor pan. When that is welded around the outer and inner circumferance this mount should be as strong as it ever was.
John
I LOVE this thread!
pm5471 (02-17-2015)
  #335 (permalink)
Old 08-12-2013, 03:49 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Looking good John.
Keep it coming.
  #336 (permalink)
Old 08-12-2013, 06:41 AM
Wiki Edits: 27
foil air dam
sometimes you can use aluminum foil or the foil tape air condition installers use on duct work to make an air dam around the weld area to keep the shielding gas in place while using a fan to have a safe breathing zone
  #337 (permalink)
Old 08-12-2013, 08:01 AM
I did not know there was a welding respirator. Learn something every day.
John
  #338 (permalink)
Old 08-12-2013, 08:04 AM
I use a disposable one because the others won't fit in my Cherokee helmet. PPE - Respiratory Protection | Disposable Respirators | 3M 8214 N95 Particulate Respirator w/ Face Seal, 10/Box | 652625 - GlobalIndustrial.com
Do get one John, I have heard a few horror stories. A fellow on another site almost died from one welding job where he installed a rad support on a Honda while it was stuck in a corner on the frame rack. They found him unconscious laying on the floor! He spent a week in ICU and is forever damaged with a stint in his chest to self administer shots of steroids into his lungs. Zinc fume fever is REAL and very dangerous. I'm sorry I didn't mention this earlier looking at your progress is so damn much fun I forgot to preach as I usually do about safety.
  #339 (permalink)
Old 08-12-2013, 08:12 AM
1971BB427's Avatar
I think most people will find a welding respirator is an expensive item, and unless you were doing a ton of welding on galvanized metal, not necessary. The smoke that comes off is easily dealt with by having the fan blowing at you, and not the material being welded. It keeps any smoke away before it can reach the person who's welding.
I also hit the areas I'm going to weld on with a grinder to get some of the galvanizing off before welding. Probably not necessary on spray galvanizing, but with hot dipped it's pretty thick, and doesn't weld well if I don't remove some.
I used all galvanized EMT on the framework of my tilt frontend, and with a fan I had no problems, and never have had previously.
  #340 (permalink)
Old 08-12-2013, 08:28 AM
My health is well worth the $20! I am not kidding, Eric, the guy I mentioned, his life changed forever with one job, done deal, his lungs are destroyed. This happen when he was 23 as I remember. But when we will spend $20 for a burger and a beer, I think it's good money spent.
Fans help, and "could" be enough if used properly, but we move around, we forget. Doing something like Johns floor, he is stuffed inside of a "bowl" welding on the bottom, the fumes (Fumes are tiny pieces of the burnt material in the air that we are breathing, read that zinc, we are actually breathing the zinc) are filling the "Bowl" and it is very hard to get it all out before we breath it. It's like AIDS, it never bothered Freddy Mercury or Rock Hudson, until that one time............
I don't want Johns great thread to be taken over by my preaching that darn old health stuff so I won't anymore. Enough has been said from me.
The Following 2 Users Say Thank You to MARTINSR For This Useful Post:
1GH (11-29-2013), pm5471 (02-17-2015)
  #341 (permalink)
Old 08-12-2013, 08:38 AM
1971BB427's Avatar
I didn't realize they'd gotten that cheap ($20) Last time I looked at them the canisters were almost $80 a pair. At $20 they're too cheap not to use. Where did you see them for $20? The link you attached says $72.
  #342 (permalink)
Old 08-12-2013, 08:39 AM
Faith - Respect - Trust
Fans help,
I'm a "fan" of pretty much everything you post Brian, and if you think I could help...let me know, I'll help....LOL
Seriously, I do agree, many of us had welder's flash...it burns the eye's something crazy the next day...we learn and religiously wear a welding helmet after. Unfortunately, as Brian mentioned, you may not always get a second chance with the off gasses that you get when you weld.
$20.00 is pretty cheap insurance...and what kind of place charges $20.00 for a burger and a beer....up here in Canada we can buy a dozen beer (depending on brand) and still have enough money left for a pound of hamburger...LOL
Ray
  #343 (permalink)
Old 08-12-2013, 09:04 AM
Good info guys. I have welded galvanized metal and indeed it is nasty stuff. This weld-thru primer does not give off the smoke or fumes the metal does and I had not given it a second thought. I will be cautious as I go forward though. The Zinc probably gives off at least a limited amount of fumes.
John
  #344 (permalink)
Old 08-12-2013, 09:53 AM
That's for a box of TEN! And internet deal for sure, at my local hardware store they are about $20.
  #345 (permalink)
Old 08-12-2013, 07:26 PM
I wear the same half-face respirator when I weld as I do for light painting. I can just barely fit my helmet down over it. If I don't wear it when I weld, I get a headache, and it doesn't take very much.
If John does any painting, which I know he does, then he's already got the equipment to keep himself safe while he welds.
The Following User Says Thank You to Lizer For This Useful Post:
John long (08-12-2013)
rust repair blackchevy3de Body - Exterior 0 06-22-2010 06:15 PM
What to do for this rust repair? chevymike Body - Exterior 5 06-04-2010 05:49 AM
Rust repair help mydixie Body - Exterior 3 02-22-2006 07:07 PM
rust repair fennerford Body - Exterior 3 12-28-2004 04:30 PM
Rust Repair gguertin145 Body - Exterior 5 11-27-2003 07:02 AM
