53 Belair conv rust repair - Page 36 - Hot Rod Forum : Hotrodders Bulletin Board
  #526 (permalink)
Old 09-27-2013, 06:53 PM
There is not a lot to post for today but there is some progress of sorts. The trunk is now empty and all the spare stainless, skirts, and upholstery panels are stored elswhere. Gee, I hope I remember where when the time comes.
It is amazing how good the structure is back here. Yes, all the mounts will have to be replaced, as well as the floor pan, but all of the convertible braces, supports, and structure appear to be intact. Believe it or not, I had never pulled the rear seat and did not expect to find this.
Here is a picture of the area under the rear seat.
Here is approximately where the rear body mount goes. I laid it in there just for a visual aid. The mounts there at the B pillar are convertible only and will also need to be built. To the best of my knowledge no one makes them.
There also has to be a system to temporarily support the body while I replace the rear mounts and pans. I am still thinking about that one. Since my intentions are to raise the driveshaft tunnel some and C-Notch the frame I may replace the front panel that runs full width between the B pillars. Once it is welded in I can support the front of the body on the cross member under that panel. It wouldn't hurt to run a cross brace higher up also to keep the quarters square. Not sure but it is a thought.
The Following User Says Thank You to John long For This Useful Post:
MARTINSR (08-08-2014)
  #527 (permalink)
Old 09-27-2013, 07:08 PM
Faith - Respect - Trust
John, my mother in-law was wondering where her broom went...She's had a hard time getting around lately...could you Fed Ex it back...her big night is coming up in about a month...LOL
The back does look good, strange how there would be as much rust as you had to deal with and then run into solid metal...go figure.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
  #528 (permalink)
Old 09-27-2013, 07:14 PM
Ray
I agree. By the time I build a new drive shaft hump and attempt to deal with the rusty pitted metal I intend to replace the rear pans anyway. I do hope the channel that runs between the rear body mounts is usable though.
  #529 (permalink)
Old 09-27-2013, 07:31 PM
Ray
I did not realize it was your mother in law's. That broom is for a little bitty woman and I thought you said your mother in law was a big ............well you know.
John
  #530 (permalink)
Old 09-27-2013, 07:48 PM
John
Apparently that's her "Sportster" model...she also has the "1 ton Duelly" model when she really needs to haul....things....LOL...If you ever put asphalt down for a drive way, I'd be happy yo loan her to you for as long as you want...after a couple of trips up and down, that driveway isn't going anywhere....LOL
Ray
  #531 (permalink)
Old 09-27-2013, 07:52 PM
Ray
I'll bet she really likes you too.
John
  #532 (permalink)
Old 09-27-2013, 08:04 PM
John
No John, your wrong, she can't stand me...I have no idea why...when ever I loan her out, she gets to keep 30%....LOL.
Ray
  #533 (permalink)
Old 09-27-2013, 08:11 PM
Ray
Very puzzling.
  #534 (permalink)
Old 09-27-2013, 08:23 PM
Very puzzling.
Just joking John...she's really about 100 pounds at best and has a great sense of humor...we actually do get along...quite often.
Ray
  #535 (permalink)
Old 09-27-2013, 08:30 PM
Ray
Your wife is standing behind you. huh
John
The Following 2 Users Say Thank You to John long For This Useful Post:
MARTINSR (08-08-2014), NEW INTERIORS (09-27-2013)
  #536 (permalink)
Old 09-27-2013, 08:37 PM
John
Nope, but my mother in-law keeps slapping me upside the head.
Ray
The Following 2 Users Say Thank You to 69 widetrack For This Useful Post:
John long (09-27-2013), MARTINSR (08-08-2014)
  #537 (permalink)
Old 09-29-2013, 07:45 PM
I spent some time chipping out the undercoating in the rear seat area today. Even though it will pretty much all have to be replaced (floor pans and mounts) the vertical structure is mostly in tact. The brace that goes under the front of the rear seat will get replaced and I will have to remove the seat back support, top mechanism, and cylinders in order to get to the floor pans.
The convertible top well also will have to be replaced.
Tomorrow hopefully I can do the same thing under the car and find out if I have any structure to attach the inner rockers to in the rear. It may be a few days before I have anything to take pictures of but will post something when I get it cut out where you can see how it goes together.
In this picture I am pointing at the rear body mount. You can see it through the rusted out area.
In this next picture I have drawn how the floor channel routes between the rear braces. If I can repair the channel, replace the rear braces and replace the convertible only support at the front of the seat the body should be adequately supported until I get the trunk area done and the frame C-notched so I can build the floor pans over the rear axle.
  #538 (permalink)
Old 09-29-2013, 07:50 PM
I really wonder if that underseal that was so popular (maybe still) in the rust belt really helps, or does it just hide the rust so you THINK it's protecting the metal?
  #539 (permalink)
Old 09-29-2013, 07:52 PM
CraigK's Avatar
Last journal entry: For a change of pace
To be honest I find watching this thread inspirational. My project is so easy compared to what you do. I have had to redefine my definition of undoable basket case. Seriously, it keeps me motivated when I think I bit off to much this time!
Wery wery wery nice work by the way.
And tell Ray that broom won't start here in Canada. No block heater. It is only good for summer transport.
  #540 (permalink)
Old 09-29-2013, 07:54 PM
I think it helps for X number of years ..But... Once it cracks or the metal begins to rust it just holds the moisture in instead of out. Long term, I would prefer not to have it. once it begins to fail it comes off in big hunks. No way is it still keeping the salt water out.
John
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
rust repair blackchevy3de Body - Exterior 0 06-22-2010 06:15 PM
What to do for this rust repair? chevymike Body - Exterior 5 06-04-2010 05:49 AM
Rust repair help mydixie Body - Exterior 3 02-22-2006 07:07 PM
rust repair fennerford Body - Exterior 3 12-28-2004 04:30 PM
Rust Repair gguertin145 Body - Exterior 5 11-27-2003 07:02 AM
