Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 53 chevy bel air
Old 08-04-2002, 09:31 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Post
While the Heidt's system is great and a very good choice, I still prefer the stock x-member. Goes in just like it looks like it should. I like the bolt-in trailing arm system from the 'Stang donor car as opposed to weld-on brackets. I have seen too many of the weld-on brackets cracked. I have installed them in two cars, one being an award winning '42 Willys pickup with tilt up front end so you know the x-member looks good! I can send you a couple of articles on this conversion if you send me your email address.
[ August 05, 2002: Message edited by: willys36@aol.com ]</p>
