53 chevy rear brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2006, 05:52 PM
Last journal entry: new bracket for the ev-100 controller
does the drums come off on this car or do i have to pull the axle... 53 chevy 4door bel-air. this car has been sitting for the past 25 years. it's been brake day here in KS... thanks
Old 09-04-2006, 06:14 PM
BOBCRMAN@aol.com's Avatar
The drums are supposed to come off. But, after all the years of setting, you are better off time wise. If you take a torch and literally cut the drums off.
I had the same problem with a 54 Bel Air. Rolled it home. Put it in storage, in line with the rest of the future projects. 20+ years later I sell it to a friend. It took us two days of beating, prying, cussing and finally I cut the drums off just so we could roll the car out to load on the hauler..
GOOD LUCK
Old 09-04-2006, 06:22 PM
Wiki Edits: 31
just be aware there not cheap drums to replace. you can get them through www.chevsofthe40s.com
a cheaper way to remove the drums would be to cut the nails off the backing plate, they should come right off, with the shoes in them.
58 chevy belair 4 wheel disc brakes change over Rick England General Rodding Tech 1 02-22-2006 09:40 PM
54' chevy rear end gavinpierce Hotrodding Basics 6 02-13-2006 09:31 AM
original rear end in 53 chevy pick-up robert forshee Transmission - Rearend 4 01-16-2006 12:23 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
Rear end swap for '53 Chevy truck Bruce H Transmission - Rearend 4 12-01-2002 11:43 AM
