53 Chevy Street Rod is back on the road - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2003, 03:23 PM
Tazz
My 53 Chevy 210 2dr post had elect. problems. I replaced the headlight switch and now everything is just fine. I had replaced the headlights thinking the 6V bulbs had finally burned out then took the floor pan apart to get to the dimmer switch, it was OK. Started checking the headlight switch and found it not working properly so I replaced it with a 12v switch. I cleaned up the grounds all around and removed the turn signal and horn switched and have yet to reassemble them. I TRULY HATE Electrical problems! Maybe the next worse thing is finding the air bubble in a brake system after setting it up and not finding all the air for days.
Old 10-04-2003, 08:22 PM
Dutchman's Avatar
Old Salt
The sweatings over , time for cruzin Its amazing what one wire or switch can do, isn't it? Its efen worse in an aircraft.
Glad you found it.
Dutch
