53 chevy truck doors - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2014, 11:02 AM
having trouble getting doors to line up. any one have any suggestions that I might try to get them t line up. I am running out of thing to try. thanks in advance gene
Old 07-16-2014, 05:43 AM
deadbodyman's Avatar
Wiki Edits: 11
first off whats been done ,why were the doors taken off?
The first thing I would do when theres trouble is to remove the striker and hinge bolts so nothing is obstructing the fit then place the door in the jamb using wood wedges to align the door and see if it fits before putting any bolts in it.. If it fits well in the hole with equal size gaps all around then you know it CAN fit and give the hinges a closer look.
lets say you welded on a rocker with the door off ,the door might not fit at all knowing that the door does fit fist will save you a ton of aggravation
Old 07-16-2014, 12:27 PM
What exactly is the door doing, there are a few tricks for the odd stuff.
Old 07-17-2014, 06:54 PM
thanks for the info. I got them to line up . Thanks yall all. gene
Old 07-17-2014, 10:18 PM
Just our mere presence provided you with what you needed, cool.
1937 chevy truck doors bcovey Body - Exterior 2 05-31-2012 06:41 PM
47-54 chevy truck doors/hinge/cab dents. superdirt Body - Exterior 1 12-24-2010 01:11 PM
What doors fit a 39 chevy sedan delivery panel truck? stkupco Body - Exterior 6 10-27-2010 07:39 PM
need some 55-59 chevy truck doors IAMJR59 Body - Exterior 4 02-13-2008 05:54 PM
mounting exterior mirrors to doors - '65 chevy truck? Woogeroo Body - Exterior 10 02-27-2006 04:40 PM
