53 chevy wheelbase - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2003, 05:50 PM
Post 53 chevy wheelbase
I am building a 53 chevy pickup. I have a mustang II frontend. I am wanting to replace the rear susp. with a s-10 rear and i need to know what the wheelbase is?
Old 01-22-2003, 06:15 AM
Stinkin_V8's Avatar
Suburbanite Member
Post
Wheelbase is 116" but you probably want the track width - anywhere from 58-62" across mounting flanges. 1st gen. S-10 is 58", the 4x4 rear end is a bit wider than the 2x4 and is still too narrow with stock S-10 rims. You'll want 5-6" wider than the stock width, which you should be able to make by using wheels with less backspacing (3" instead of the stock 6"). Definately go with the newest S-10 rear you can buy if you go this route. Off the top of my head, early models used a 7.5" and then moved to a 7.625" in '87 or '89. I think they're up to an 8.5" in some of the models now.
Might be worthwhile to check out the 3rd gen. F-body rear ends as well (62"), especially if you can find one with rear disk brakes. You might have to use a lot of backspacing with that rear.
[ January 22, 2003: Message edited by: Stinkin_V8 ]</p>
When life hands you lemons, ask for tequila and salt
Old 01-29-2003, 07:02 PM
Post
thank you ! the wheelbase is what i needed. i am going to use a s-10 rearend to tub my truck. thank you again
Old 02-03-2003, 08:03 AM
Stinkin_V8's Avatar
Suburbanite Member
Post
If you've got the box and rear fenders on, mount it where you think it looks good. At 116", the rear wheels sit a little too far back in the rear wheelwell for some folks' taste. Remember to take into account that the wheelbase will get about 1/2" longer when you load the rear suspension, due to the geometry of the leaf springs.
