Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 10-19-2005, 11:21 AM
fireschenie fireschenie is offline
53 Chrysler Rear End Swap
I have a 53 Chrysler that needs a new rearend. I want to switch to a newer axle but I'm not sure what would fit. I was told at a car show that an axle out of an old Dodge Econo Van would fit but I'm not really sure the guy was creditable. So any help would be be appreciated. It's a 53 Chrysler that's all stock, it still has the original tranny and the original 331 Hemi.
Thanks Bryan
Old 10-19-2005, 05:59 PM
Centerline's Avatar
Centerline Centerline is offline
Moderator
 Centerline's barnstar
Wiki Edits: 38
re: 53 Chrysler Rear End Swap
Measure the distance from backing plate to backing plate (wheels off drum surface to drum surface where the wheels mount) and head off to your local wrecking yard to find a suitable replacement. OR you can get the measurement and one of us can look up what cars will have rears that will fit.
Your choice.
Centerline
HotRodsAndHemis.com
"Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "53 Chrysler Rear End Swap"
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 6 01-09-2006 11:10 AM
air ride, ifs, engine swap, rear end blake Suspension - Brakes - Steering 1 11-19-2004 05:31 AM
Will rear end swap work? 71gtx Transmission - Rearend 0 11-03-2003 12:56 PM
rear end swap?? trick66 Transmission - Rearend 0 04-23-2003 07:38 PM
Rear End Swap Chevydude Transmission - Rearend 2 07-03-2002 10:59 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
