Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '53 Ford Customline Antenna Location
Old 12-09-2012, 07:05 AM
Irelands child's Avatar
Irelands child Irelands child is offline
Right front fender - and almost impossible to add/replace an antenna and run the cable without pulling the fender off due to the hood hinge, heater duct, inner fender and the fact the cable goes through a grommet on the side of the fire wall and if you are using one that is a stock original appearing hard to align with the hole plus fit up the seal. I have replaced antennas on '52-'54 Fords, but only with exist fender holes and probably still have a scar or two
Irelands child
