'53 Ford rearend info HELP! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2006, 08:04 PM
im new at this (i just sighed up) and i work on/have a few rodz but the one in question right now is a '53 ford sled that i need to find a rearend that will swap in with relative ease. the issueisas a stock flattie and a 3spd. the problem is the price of gas. i need to know what rearend will swap in and what from with the highest ratio possible. i have the same issue with mt '57 and '51 also, but i want to keep the '53 all ford, if it was a Chevy i would swap in a nova like on my '50 but im not that knowledgeable on the fords. i anyone has any info please drop me a line at [EMAIL=yelton57@hotmail.com]
Old 05-25-2006, 06:09 PM
As a Moderator at Hotrodders.com
I want to WELCOME YOU HERE ...
A lot of folks use the early 70's V8 Maverick rear end ...
5 lugs wheels, a 2.79 ratio is real common and the width is about right . It also keeps the Ford ... ALL FORD ..
Deuce ...
Old 05-27-2006, 09:10 PM
junkyardjeff's Avatar
I have a mid 70s maverick 8 inch in my 55 sunliner and it bolted in and the original emergency brake cables will fit. Jeff
Old 05-27-2006, 09:13 PM
I forgot that the center section from up to 56 will bolt in back to 49,the 51 automatic has a 3.31 ratio and the 55 or 56 could have a better ratio. Jeff
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 10:30 PM
Ford Rearend Bob Moren Transmission - Rearend 2 10-15-2005 06:37 PM
Need Ford pickup truck kingpin info wp442 Suspension - Brakes - Steering 8 08-01-2004 09:32 AM
53 ford Trans & rearend Rob Graham Transmission - Rearend 3 07-22-2004 03:38 AM
Specs on a Ford 8.8 rearend Pencilneck314 Transmission - Rearend 0 11-17-2003 04:57 PM
