53ípost chop - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2012, 06:32 AM
53ípost chop
Just a little update for what itís worth..Went with a mild 1 1/2Ē chop and removed the drip rails.Keeping the curved glass in rear (looks good if itís not leaned too hard imo).S/S fuel tank from ricks with pump & filter inside.And thatís about it for now.
ID:	65670   Click image for larger version
ID:	65671   Click image for larger version
ID:	65672   Click image for larger version
ID:	65673   Click image for larger version
Old 05-28-2012, 07:12 AM
I noticed you brought the top straight down, leaned and re-angled the A pillers to meet. Is that not going to make cutting and fitting the windshield extra difficult?
Old 05-28-2012, 08:45 AM
Hey bud..Tried to keep the angle the same but only shorter.If that makes any sense..Ordered laminated glass for both front and rear so cutting it down should be much easier.Got the glass in fri so let ya know how it goes.
Old 05-28-2012, 09:02 AM
Pictures, Pictures... Lots of pictures . This will really be interesting to follow. I really enjoyed the thread on cutting down laminated windshields a month or so ago. There is no right or wrong way to customize a car but some ways are easier than others. I personally really like the 1 1/2 chop. It brings the car into proportion without looking too extreme. Having chopped a merc 3 1/2 inches I can guarantee yours will be easier to drive around town also.
Keep your camera handy. We are waiting.
Old 05-28-2012, 09:18 AM
dinger's Avatar
Very nice, I like a subtle chop on the early 50's Chevys, the kind where it brings the car into a nice proportion as to where you have to look hard to see the chop. As John sas, post pics, this will be a cool build. Dan
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 05-28-2012, 09:50 AM
Heck yeah that looks good. That mild of a chop changes everything in the difficulty dept, things go sooooo much smoother with a little less cut out. I am thinking with that little cut leaning the A pillars back did't change the shape of the hole that much. But without a doubt get that glass cut so you can fit the top to it as you finish the chop.
Old 05-28-2012, 10:04 AM
boatbob2
Chop Top,,,,,,
Hi,ive only chopped one top,and cut down one windshield,so im NOT the authority. BUT,what i did,was use a 1/8 inch door skin (HD) to make a pattern,then after the skin,fits the hole,perfectly,i put it into the rubber weatherstripping,and installed the skin,as a windshield,(i had to make 2 patterns) then,when i was satisfied with the fit,i removed it from the weatherstripping,and duct taped it to the new glass before cutting.
Old 10-13-2013, 12:04 PM
A little more progress: Top done,glass out being cut,bottom all stitch welded and ground.Booster,a/c fitted.Steering column was a little long but worked out ok.Fenders blasted fixed up and POR'ed / epoxy primed.Body now back from blaster.Will spray frame a satin (like suspension) and belly w/lizard skin?
ID:	88810   Click image for larger version
ID:	88818   Click image for larger version
ID:	88826   Click image for larger version
ID:	88834   Click image for larger version
Old 10-13-2013, 12:15 PM
Few more.Hope to have more soon.
ID:	88850   Click image for larger version
ID:	88874   Click image for larger version
Old 10-13-2013, 04:25 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
nice work ! i like a small chop . extreme just doesn't work on everything. the glass guy i use to use would sand down windshields on a wet belt so he could fit them. plus he didn't break any . i could retire on the windshields i've busted .
keep the picks coming .
Old 10-14-2013, 03:20 AM
Sorry for the random order of pics.But,I know you sharp fellas can put em in order.Had a decent thread going at the HAMB but they were taken down as soon as I posted the body back from the blaster.
ID:	88986   Click image for larger version
ID:	88994   Click image for larger version
ID:	89002   Click image for larger version
ID:	89010   Click image for larger version
Old 10-14-2013, 05:23 AM
Was it not "traditional" enough for them?
John
Old 10-14-2013, 06:04 AM
John
I guess not.Suppose the cage gave someone cardiac arrest.Looks like i'm here to stay.
Old 10-14-2013, 06:08 AM
Cool, We need all the 53 Chevies we can get. Keep the pictures coming. I have enjoyed watching your build.
John
Old 10-14-2013, 08:33 AM
God that's bizarre! Life is too short to act that way, and life is too short to put up with it.
How can I remove 2 door post trim from the post and door frame? 1964 Oldsmobile 442 Body - Exterior 1 07-17-2011 05:41 PM
doing a chop top on a 53 bel air 2 door post chino_chao Body - Exterior 1 12-26-2009 01:08 PM
To Chop or not to Chop 1931 steve Body - Exterior 23 03-20-2008 11:23 AM
chop or not to chop 32wizard Body - Exterior 3 03-08-2007 06:57 AM
Not really a tech post but a progress post 68 c-10 Zumo Hotrodding Basics 6 03-06-2006 09:24 PM
