'53 r130 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
Old 11-20-2012, 06:10 PM
Last journal entry: Update
'53 r130
Here's the way I found the old 'Binder 2 weeks before I bought it . Mine was in the middle of 2 1952 L series trucks.
ID:	69259   Click image for larger version
ID:	69260   Click image for larger version
Old 11-20-2012, 06:17 PM
After getting it home I started tearing the engine down only to find # 4 piston was seized solid in the bore. I fought with it for a couple of hours and finally broke it free ( broke being the operative word)
ID:	69262   Click image for larger version
ID:	69263   Click image for larger version
ID:	69264   Click image for larger version
Old 11-21-2012, 10:33 PM
Move this thread please
I'd like this thread moved to a build site if possible thank you.
Old 11-22-2012, 06:58 AM
CrashFarmer2's Avatar
Freezing in arctic Iowa
Last wiki edit: Pre-1980 VIN decoding
Last journal entry: 1978 Chevy pickup battery tray repair
Wiki Edits: 409
Does it have a 9 foot box? It looks like it from the picture.
Old 11-22-2012, 08:04 AM
The only "Build site" is the one thread on "What did you work on today" in the Lounge. Or you could post it in "General Tech" but usually posing the particular questions in the appropriate forum like engine questions in the engine forum that sort of thing.
Do you plan on rebuilding the motor or swapping in different motor? Rebuilding that one would be more expensive but in my opinion in your truck it would be the cool way to go. But it's all up to YOUR expectations as we all think differently.
Old 11-22-2012, 07:50 PM
I will be rebuilding the original engine (all numbers match) however I am looking to improve on the gear ratio in the diff 7.39:1 is a bit too low unless you can rev to about 20,000 RPM In answer to the length of box is on it it is actually 9'6" long inside. BTW anyone interested in building a rock crawler 4X2 ???. I got a bullet proof rear end I'll sell REAL cheap.
Old 11-23-2012, 10:49 AM
dinger's Avatar
Cool looking truck, I like the old corn-binders. I don't know why more aren't hotrodded, unless it's difficult to stuff a SBC under the hood...
This is the proper forum for your truck, unless there's a tech question or some advice, we try to keep these topics in the Lounge. More folks will see it here also.
Start a journal. This will also get your pics posted on the main page of the site. It will be interesting to see the progress.
I didn't know gears that steep were installed on anything from the factory. Holy Cow!
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 11-23-2012, 12:50 PM
Back when this old girl was built you could get just about any gear set you wanted. I will be starting a build journal as soon as I get around to working on it again ( the engine is presently in the back of my '83 GMC for weight LOL)
Old 11-23-2012, 10:26 PM
As for your question about fitting a SBC in them it is easily done although a 5.0L Ford fits better. these old gems have plenty of room under the hood. Some people are dropping 7.3 Powerstrokes in them without modifying the bodies. The only issue most run into is the steering shaft getting in the way but this can be easily fixed by using U-joints and modified shafts/steering boxes.
Old 11-24-2012, 12:04 PM
Wiki Edits: 409
Apparently those long boxes were popular on the ton trucks. My brother has a 50 Dodge with a nine foot box, I should measure it to see what it is exactly though. My 59 IH is a shortbox but it's only a half ton. I like the old IH's. I wish I could have bought my neighbors at his estate sale but I just didn't have the fiances at the time, he had the series that would be one before yours.
Old 11-24-2012, 08:58 PM
That would have been the L series 1950-52 BTW here in Alberta you can pick these up for under $750 easily Both mine were $500(R130) and $300(R160) I'm also working on getting a '47 Hudson I think I can pick up for around $500 with a very good body and glass.
ID:	69339   Click image for larger version
ID:	69340   Click image for larger version
Old 11-27-2012, 10:40 PM
I've been wavering on the rebuild of my SD220 engine from the R130. I am not sure whether that old slow turning, torquey engine is worth it. These engines have a red-line of 3800 RPM and put out 100 HP @ 3600 RPM These engines have a 3 9/16" bore and 3 11/16" stroke and weigh in at over 600 pounds bare. However they will pull up a redwood tree just as sure as I'm sitting here.
Old 04-08-2013, 10:58 PM
Today I bought a donor truck for all the parts I want for my old 'Binder. I picked up a 1990 Ford F350 with a diesel engine, 5 speed tranny and decent rear end for $1000.00. The cab is pretty much rusted to hell but the mechanics all seem to work. He even threw in a pair of brand new batteries for me
Old 04-09-2013, 04:19 AM
poncho62's Avatar
Wiki Edits: 5
Cool build...Are you going to use the service box from the Ford too?
BTW, moving this thread to the new Builds forum
Old 04-09-2013, 08:20 AM
I'm thinking about using it as I am a mechanic by trade and I think it would be an interesting looking truck when it's finished. I'll know better when I get them side by side.
