53 Stude rack & pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2005, 08:07 PM
R & P from 80 Vette donor work under my 53 Stude without too much trouble (or not at all) will be running sbc.
Old 01-23-2005, 08:45 PM
powerrodsmike's Avatar
Wiki Edits: 161
r&p in a 53 stude
the first thing you need to find out is if the rack will work with your suspension/ steering geometry. your inner tie rod ends on the rack need to line up with an imaginary line that bisects the inner pivot points of your upper and lower control arms.here is a page from heidts that explains it way better than me. http://www.heidts.com/heisinfo.htm. I know this- if you don't follow these design parameters your car will not only be unpleasant to drive, it will be unsafe as well.
BE different....ACT normal.
Old 01-24-2005, 06:48 PM
Thanks for info powerrod, will look at heidts.com and try to learn something.
