53 Suburban Shock placement - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2005, 04:57 PM
Sly's 53 Suburban's Avatar
Last journal entry: Completed the side window installation
I ran into a problem while preparing to install the body back on the chassis. Originally, the left and right rear top shock mounts are forward of the axle. If I remember correctly, in the mid 70's, the right shock mounts are forward and the left mounts are behind the axle. On my 53 Suburban there isn't enough clearance for the shock to pass the emergency brake assembly at the disc. Can I relocate my right rear top shock mount behind the rearend and leave the left top mount in front of the rearend? I'm concerned with the issues torque may cause if I mount this way
Old 07-03-2005, 08:23 PM
jalopy45's Avatar
The shocks are mainly to reduce the impact force of sudden jolt and to smooth out the transition of axle movement. Unless you have an awful lot of torque the shock placement will have little effect. As long as they have free movement in and out , both behind, or in front or staggered will work fine.
Old 07-03-2005, 08:58 PM
Great,
Thank you jolopy45 very much for your response. I was hoping I didn't have to swap out the rearend.
Optimum rear shock angle jpd37 Suspension - Brakes - Steering 42 05-24-2005 04:55 PM
Coil over Shock Selection jhenry Suspension - Brakes - Steering 1 03-15-2005 01:35 AM
shock absorber travel bb66gmc Introduce Yourself 4 12-21-2004 06:47 AM
shock travel bb66gmc Suspension - Brakes - Steering 2 12-16-2004 09:14 PM
Lever Shock is in the way! rwruther Suspension - Brakes - Steering 0 06-11-2004 02:20 PM
