53cc heads on 355? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2012, 08:23 PM
MrPhotographer06's Avatar
Army Strong
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
53cc heads on 355?
I bought a 305 from a buddy out of a 82 k5 blazer. turns out, it has the 53cc heads. the 601 casting.
I know they have 1.84-1.5 valves, and flow like 165 cfm at .050".
But, im trying to figure a way to utilize all the parts, and make something out of them. If i use the 305 block, i'll probably do some other head on it, but it'll be 3 projects down the road.
Im tossing the idea of a high compression 355, with flat tops, 53cc heads, and a .500 lift cam, 750 carb, high rise intake. Does this sound like a 700 lb grenade, or a feasable build?
not sure what i'd use it on, but its an idear. I may put it in my truck after i build it to its jacked up build, or i may use it in another strip car.
Plausable, or busted?
Old 04-22-2012, 09:07 PM
To me sounds like a cool build, I would try using the 62cc Vortec heads, and just have them machined for more lift and a victor jr intake manifold, sounds like the same build as mine, what CR are u looking for? What are you plaining on doing with this build?
-Phil
Old 04-23-2012, 07:38 PM
Army Strong
f-bird, sounds great, thanks for all the info.
I've had a little experience watching a couple P&P jobs, and a few valve jobs, so we'll see where to go from there.
and, Phil, I have a set of vortecs, but i kinda traded them with my dad for a 88 dodge dakota. I traded him my 84 Camaro and all the goodies to go with it.
I was planning to drop a 383 from one of my buddies that he already built from his 73 Road Runne into the Dakota
But, if i decide to do this 350, i need a good vehicle to drop it in. the junkyard beside the house has a 71 Monte Carlo, my absolute FAVORITE 70's car, closely tied with the 78 z28 camaro.
If I can the Monte off the old man, it'll go in that.
If not, its just a mental build and stored in the shed til I find out what to put it in.
Old 04-23-2012, 09:33 PM
Awesome, sounds like a cool project, good luck with the build
Old 04-28-2012, 09:24 PM
Army Strong
'preciate it. Should be a fun project
how much CR with AL Heads, 355 chev, and 91 octane bigalow Engine 11 11-02-2011 10:28 AM
Heads 62cc or 76cc for a 355 99 to Life Engine 2 02-13-2011 10:22 AM
355 w/ vortec heads abas_abas Engine 11 03-24-2009 05:54 AM
355 SBC heads zildjian4life218 Engine 5 12-08-2008 09:49 PM
355 What heads should I use? novaguy355 Engine 3 08-16-2008 04:23 PM
