54 3100 454 install - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2013, 08:05 PM
54 3100 454 install
Hey all, about to start my 454 install on my 1954 Chevrolet. I think I got the motor mount placement handled and I have a recessed firewall. The problem is when I mock everything up I only have about 2 inch clearance from my radiator and I need to take the firewall back even more for distributor clearance. Does anyone has any tips or advice for me?
Old 01-19-2013, 07:38 AM
Wiki Edits: 27
steering gear
Years ago we had to make a new angle iron bracket to move the steering gear to get clearance on a 1/2 ton. There is plenty of room in the nose to move a bigger radiator foreward.
Old 01-19-2013, 08:43 AM
Where is the radiator mounted, behind or inside of the rad support? What radiator are you running? I have seen the radiator mounted all different ways in these trucks and it can make a heck of a difference of course.
The radiator originally sat behind the support (nearer the engine) kinda half way, so with the upper bar that goes over the radiator and bolts to each side of the rad support removed and modified you can move the radiator forward about two inches. I have even seen radiators mounted in front of the radiator support completely! This truck had an inline six originally there is plenty of room for a V8. Never did a big block but a small block fits no problem.
Old 01-19-2013, 05:17 PM
It is a 3 core Alluminum APR and as of right now it is inside the support. I'll take a better look at the support to see what I can do. Thanks for the tips, I'll post some pics soon.
54 bbc install
454 going into my 53 3100 chevy53 Engine 10 01-18-2013 09:24 PM
My 454's all-Zoops Products install steven_oharra Hotrodders' Lounge 23 03-15-2011 03:06 PM
454 install 1961 c10 truckboy61 Engine 1 06-19-2009 06:17 PM
install a 454 in my 89 hardbody str8blazed661 Hotrodders Site Suggestions and Help 1 08-19-2007 02:17 AM
IFS Install, 51 3100 slstusmc Suspension - Brakes - Steering 3 07-24-2006 06:22 PM
