54 5 window truck top chop and corner glass - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2004, 09:40 PM
Roadsire's Avatar
Last journal entry: Dash mods
Thumbs up 54 5 window truck top chop and corner glass
I have a book on chopping it shows a 54 being chopped but it does not mention anything about the corner glass. I know that this is tempered and cant be cut unless it is annealed cut and re-annealed, I have thought about recessing the glass but dont want to cut into the window frame fearing moisture entry i suppose plexiglass would work but not my first choice. any suggestions?
Old 06-28-2004, 03:10 PM
New Member
Check out this thread.
http://www.rodder.com/cgi-bin/ubb/ul...;f=13;t=000217
Part way down it is mentioned that laminated glass quarter windows are available which can be cut down.
Keith
Old 06-28-2004, 05:07 PM
Roadsire's Avatar
Talking %4 chop
Kieth
You are the man! I emailed them to see if they can help me out.
I didnt want to have to drop the glass in the cab or use plexiglass or saran wrap. Ironiclly I work with glass a lot stained and fused art glass and was actually thinking about re annealing the glass but what a distater it could be. so thought no chop we shall see. thanks again Will
Old 06-29-2004, 10:15 PM
Roadsire's Avatar
Hey kieth
I called him about the laminated cab corner glass and he has them, so I gues Im starting the chop.
cut weld, grind....sleep repeat
Thanks again....
this place is a wealth of info
