I am sure different people would approach things differently. I will assume that you have new seat covers or have sewed some together, so I will describe what I do on assembly. From my experience, I start with the wire frame. I make sure what should be straight is and what should be coiled is as well (no broken springs). I clean off any rusted parts and paint the metal frame work so rust would not come through the fabric. Then I take a twine and tie the ends of the springs into their position. This keeps everything just where it should be in the building process. To wrap up this first process, I then take a piece of burlap and attach it to the seat frame. Now for padding, choose what you will for your base... horse hair for the real old or go right for the foam. I usually hold the foam in place with a fabric layer (so it doesn't protrude into the final cover). I then put a couple thin layers of cotton batting over my foam cover as my top layer, so if I find that a corner is not padded enough, I can add more cotton and get my top cover to lay correctly. I then hogtie the cover in place with just a few rings and look at the seat... I add or remove more cotton as needed to have the fabric lay smoothly, and hogtie the rest into place (starting from the center of each side and working to the corners). Like I say though, different people do it different ways... try it out and if it doesn't look right... unhogtie it and do it again until it does. best of luck |
The older padding materials invite rodents to take up residence inside your car. Re-padding the seat frame with modern materials is extremely simple, eliminates the rodent problem, and will make your seat sit better and last longer. Check out this thread, it will tell you exactly how to replace the old padding material in your old seat: CLICK HERE also check out this thread, it will help with seat spring repair: CLICK HERE
Here's how those old seats turned out.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ Last edited by DanTwoLakes; 03-14-2009 at 08:23 AM. |
BTW, all the moderators have been asked to remind everyone not to entitle a thread with the word "help" or "need help". If you do, when someone searches for an answer that you may get in your thread, it won't show up in the search. I am going to change the title of your thread.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
My apologies for the help word... I'll try to remember that next time
I have a question. So I'm concerned that any cotton that I stuff in won't stay in place on a seat back unless I cover the whole thing with a hogringed fabric layer before I pull the final cover on top. If I do end up with a good base foam and cotton layer under a final fabric layer(under the final cover), if I add cotton to fill out the weak spots, will the stuffed cotton stay in place after some use? Maybe I'll have to post some pics... this seat back frame is different... really! It has some "moving parts"....! Thanks so much for the info! |
Don't worry about the "help" thing, it's no big deal.
I don't use cotton for anything, and haven't in many years. If I want to add filling material, I add dacron polyester wrap. I always glue it on with foam to foam glue so it can't shift. This has the added benefit of allowing the fabric to slip on the dacron, which makes it easier to assemble. No, the stuffed in cotton will probably not stay exactly where you put it to begin with.
Ahhhhhhh....ok... that makes sense... so you would glue some dacron onto the foam trouble spots only and not cover the whole thing with dacron and a fabric layer that is then hog ringed to the frame? Maybe the fabric layer(not the final cover) is overkill...
I've got like a 2" non-hr foam on the back so far....I'm having problems getting the upper corners fitting nicely without puckering... Buttons/attachment are an upcoming problem... |
I would always put dacron wrap over the entire seat, not just in certain areas. Yes, the fabric layer is overkill and will not actually do anything. Go back and look at the blue seats a few posts back. There is nothing under those seat covers except 1" of 65 compression foam over a 3/8" deck pad attached to the springs. Nothing had to be added and nothing needed to be done to the corners, etc. Without trying to be critical, and without seeing the actual seat covers, if you are having trouble getting the seat covers to look right, there is something else wrong that needs to be fixed.
So is this a typical seat back spring unit?
First picture is of the top of the unit... is the bar that curves towards the back supposed to be the back top edge? So the deck pad would be attached to this? Second pic - just the spot in the middle of the frame that shows where this piece has some movement... just a bit... Third- a non-original front seat corner picture... trying to show how this top edge is supposed to look... My mock up cover could be just too big, perhaps... I did sew a half inch seam... |
It's a pretty typical coil spring unit. That's a border wire which should go all around the perimeter of the front of the seat and yes, the deck pad should be attached to it. Can you take a picture a little farther away? The third picture is of the back of the front driver's side seat back corner, right? From the seams that are visible, the front of the seat curves in toward the center from the outside edge, and also curves back toward the welt cord, right?
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ Last edited by DanTwoLakes; 03-16-2009 at 10:02 AM. |
No, I have never seen one like that. Most seats would be flat and squared off on top, and be level with the rear, not curve up and over. That configuration would make it harder to do, but still not a big deal.
Yes, the third pic is from the back of the driver's seat..
Yes, the curves do as you said... Attached pic is of unit laying down on foam... passenger side... So does the cover end up pulling that top wire edge into place so the back unit edge doesn't show thru the cover? My pics are cropped a lot to fit the 300 kb max size allowed ... |
If this was something I was doing, I would pad the back side of the spring unit, at least all around the outside edge. Or....I would glue 1/4" sew foam to the fabric on the back of the unit. I would also glue 1/2" sew foam to the fabric that makes up the front side. That alone will make this job a lot easier. The border wire will pull in some, and provide resistance against the fabric on the front side.
ok...after much frustration with the fit of the mock up cover, I got hold
of the take down pics of this seat and lo and behold, I'm not going nuts! I needed to have the seat frame to get the correct fit for my cover... Phew!... Thanks so much for all the advice and tips... I'm going to get some different padding and try that, too.! I'll let you know how this turns out... |
| Recent Interior posts with photos |
| buckets and back seat for 55 210? | DeathByGreaser | Interior | 4 | 04-26-2003 04:11 AM |
| Nova Back Seat | novachad | Interior | 2 | 03-24-2003 02:14 PM |
| Seat repair question | Stinkin_V8 | Interior | 1 | 02-14-2003 07:25 PM |
| 65 gto back seat | culver 76 | Interior | 0 | 10-20-2002 08:00 PM |
| How do I get the back seat out??? | BadBowTie | Interior | 4 | 03-17-2002 10:34 AM |
