54 chevy - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-07-2013, 02:28 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Did you check for a vacumn leak ,hose off at intake or modulator,? Bad brake booster, have you made any recent repairs ,if so what.
  #32 (permalink)
Old 04-07-2013, 05:30 PM
Z28
It been sitting for about a year i put fuel pump to get back running been runnihg high. replace all the electonic on the motor. try spraying water for vacumn leaks have not replace map
  #33 (permalink)
Old 04-07-2013, 07:02 PM
Built Not Bought
This might take a little trial and error .if no vacumn leaks try spraying carb cleaner or starting flyid at all vacuum ports and linec ,then I would check idle motor for carbon build up underneath take off and clean also clean and inspec tEGR valve ,the throttle sensor could cause high idle but normaly would surge up and down ,may be this is a start.I am asumeing it is fuel injected.
  #34 (permalink)
Old 09-20-2013, 07:34 PM
54 chevy
These photo show ride height without engine and trans it sits about 2 inches lower with engine has stock springs from an v6 ,4.3 with air, other showsbetter shot of front bumper mounys i made,
Ok had to put thing on hold . Putting cab on frame on 4X4. using 2x4 tubing .look like center your front wheel.
  #35 (permalink)
Old 09-20-2013, 09:06 PM
Built Not Bought
I got to work a little more on mine ,here is some changes I made ,I didn't like the factory black backsolash in grill so I painted it red .
Name:	update grill 001.jpg
ID:	82537   Click image for larger version
Name:	update grill 004.jpg
  #36 (permalink)
Old 09-20-2013, 09:21 PM
Built Not Bought
A couple more photos showing wheel placement in wheel well
Name:	bumpers splash pan & rear fenders 003.jpg
ID:	82553   Click image for larger version
Name:	bumpers splash pan & rear fenders 001.jpg
  #37 (permalink)
Old 09-20-2013, 09:34 PM
CraigK's Avatar
Last journal entry: For a change of pace
Nice job 426
  #38 (permalink)
Old 09-20-2013, 09:39 PM
Built Not Bought
Originally Posted by CraigK View Post
Nice job 426
496 not 426 LOL 426 is a Mopar ,,496 Chevrolet 8.1 litre.
  #39 (permalink)
Old 09-21-2013, 09:15 PM
That is very nice
  #40 (permalink)
Old 09-21-2013, 11:24 PM
Built Not Bought
Thamks a lot , a slow go.
  #41 (permalink)
Old 09-22-2013, 02:27 PM
CraigK's Avatar
Still nice job. If mine turns out half as nice as yours I will be happy.
Sorry about the typo. It won't be the last typo either.
  #42 (permalink)
Old 09-22-2013, 06:57 PM
Built Not Bought
I am sure ut will turn out as good or better than mine I am doing all of my mechanical work ,body work and interior my self ,But the paint is being don by my son Kelly as I cannot paint any more ,LUNGS copd, I am assembling as I get time between other jobs,I guess it is pay back time for all I have built and painted for him ,when he was only learning to do this type work,
post some pictures when you get time
153 tooth Chevy flywheel in an original '55 Chevy 3 speed stick. Classic Chevy Dave Engine 2 09-17-2010 03:44 PM
newer chevy distributer in older chevy car,what are these four plugs? gearjammer38 Electrical 11 08-09-2010 10:15 AM
Putting a 72' chevy 350 into 1995 chevy silverado that has a 4l80e trans Willbee26 Transmission - Rearend 3 03-28-2010 10:40 PM
Chevy 350 Engine & Trans in a 46 Chevy Pickup Warner Engine 4 02-11-2005 04:44 PM
Small Chevy car wheel to fit Chevy Truck musky2 Transmission - Rearend 4 03-16-2004 08:12 AM
