'54 Chevy and disc/drum conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2009, 06:08 AM
I am changing a '54 Chevy over to disc/drum and have the following components - 7" booster, early Vette master cylinder, GM A body discs and calipers in the front and a Nova rear end with drums. I also plan on using a 10 lb residual valve in the rear line and a 2 lb valve in the front line since the booster and master is under the floor mounting on the frame. My question is should I use an adjustable proportioning valve in the rear or use a combination valve from a donor car or the aftermarket. Are the aftermarket combination valves one size fits all? Also if using the adjustable proportioning valve, is a metering valve necessary. I have seen numerous diagrams both with and without metering valves.
Thanks for any input.
Old 03-09-2009, 10:52 AM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
I have always been hesitant to use an after-market combo valve. Without knowing the specifics of the vehicle (tire combo, weight distribution, c/g location, etc) it would be a crap-shoot to get the right one. With at setup like you have, I would be very comfortable installing the components you describe and just installing the adjustable proportioning valve with no metering valve. I have done it that way many times and as long as the braking components are a well balanced brake package (don't install 13" rotors and 6 piston calipers on the front and 10" drums on the rear), and your tire/wheel dimensions are similar front to rear, you should be able to adjust the balance just fine.
Andy
Old 03-09-2009, 11:12 AM
Thanks aosborn!
The main thing I was worried about was/if I needed a metering valve.
Disc/Disc vs Disc/Drum master cylinders rlvirago Suspension - Brakes - Steering 6 02-28-2007 04:33 AM
Brake Lines for 1968 Chevy SWB 68chevytrkr Suspension - Brakes - Steering 2 10-03-2006 03:34 PM
Master cylinder: Disc/drum vs. drum/drum wp442 Suspension - Brakes - Steering 4 09-28-2004 03:46 PM
disc/disc or disc/drum unstable Suspension - Brakes - Steering 1 05-06-2004 01:12 PM
