54 chevy with mustang2 front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2006, 07:56 PM
I have a 54 Chevy and installed a mustang 2 front end in it. I did not want it to be low in the front so I did not use the drop spindles in it. My problem is it is still to low . How can I pic the front end so it is not to low it hits the ground when I go over any bumps in the road ???????
Old 07-31-2006, 08:18 PM
Wiki Edits: 49
If you didn't use dropped spindles it shouldn't be that low. It sounds you may have used springs that are a little too soft.
One question, are the lower "A" arms level with the ground? If they aren't the springs are most likely your problem.
Old 07-31-2006, 08:37 PM
54 chevy with mustang 2 front end
I there any way of telling what size the springs are? I remember telling the guy I order from that I did want a heavy spring but that does not mean it is what he sent ?
Chevy truck Tilt front End! Onestophotrodshop Body - Exterior 0 12-01-2005 11:26 AM
Caprice front end to '39 Chevy. udu56 Suspension - Brakes - Steering 6 08-09-2005 07:48 AM
64 Chevy Front End 64 C-10 Suspension - Brakes - Steering 4 07-31-2005 11:00 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 04:08 PM
rebuilding a 54 front end? Conner Suspension - Brakes - Steering 10 04-29-2002 06:54 AM
