54/chevy/pu/cab/and bed/to a 1991 s10 frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2005, 07:47 AM
New Member
good morning.can any one help me out .i want to put my 54 1/2 ton cab and bed on an s10 frame anyone ever done this, and can you help me out on this project
Old 04-17-2005, 11:25 AM
Wiki Edits: 49
This has been discussed numerous times in the past. Check out this link and just look for discussions about swapping frames. You'll find a LOT of info about just what you want to do.
Old 04-17-2005, 05:22 PM
Tazz
the bed will need modified...
to set level over the hump in the frame once the bed is setting down...the floor of the bed will need raised up just a bit.
Tazz
Rat Rods Rule!
Old 04-18-2005, 12:53 PM
Stinkin_V8's Avatar
Suburbanite Member
Just a thought I'd had while doing this frame swap on my Burb, but if you mounted the back of the cab a bit higher than the front, you should be able to mount the cab and box in line on the S-10 chassis. Not sure how much the frame will hang down at the back.. I raised the floor in my 'Burb a tiny bit and still had to extend the S-10 frame down to match the 52 bumper.
*NOT to scale*
When life hands you lemons, ask for tequila and salt
Old 04-18-2005, 02:10 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Just something one can do
if you were to set the cab and bed on the frame and use some wood blocking and wedges to get the cab and bed in the correct attitude then you can figure out just what you need in way of mounts..
Probably a good idea to temporaily mount the fenders as well so you can find just what needs to be adjusted..
This shoudl tell the tale..
OMT
47-55 Advance Design Chevy on a S10 Frame articles? tyman00 Suspension - Brakes - Steering 28 01-11-2006 08:43 AM
34 ford on s10 frame motor mounts jaxhome Engine 2 04-03-2005 10:15 PM
53 merc on a s10 frame 53fordguy Hotrodders' Lounge 2 10-22-2004 12:24 PM
What type of body??? with s10 frame 12second6 Body - Exterior 5 03-31-2004 05:32 PM
s10 frame question mitmaks Body - Exterior 7 02-04-2003 03:53 PM
