54' chevy rear end
Got my tax return coming, and I'm spending it! I have a 54' chevy 4 door 210 which is a good driver. Just drives like a 52 year old car. I just redid the brakes and they are still scary. And I want a car I can feel safe driving my family in. So, I decided to redo it. I ordered a complete TCI front end with disc brakes and all. I am going to put a v-8 in it too. My question is about the rear end. I have to ditch the torque tube, so what are compatable rear ends for these cars? I have a 69 camaro rear end that is in great shape, but I'm pretty sure it's too wide? Anyone else know what rear ends fit? The other thing I need to know is what steering columns will work? I know I can go with the after market, but I would like to go junkyard style on that one.
A 67 and a 69 Camaro rear is the same width. A 53 and a 54 Chevrolet are the same underneath. SO.....you should be good.... The preferred steering column around here is the mid to late 70's GMC/Chevy Van...tilt steering column. They have the P R N D d2 d1 on the column.........and have no key on the column.....the neutral start switch is also on the column....... Perfect for adapting
Good news on the 69' chevy rear end working! As for the steering column, I would like to retain the original look of the interior as possible so is there anyway of modifying the original. Maybe cutting it short and installing a kit of some sort to make it work?
Are you going to run a automatic or a manual shift ?
And ....what type of column did you currently have in the car....automatic or manual ? |
Right now it's a 3 speed column shift. I want to switch it to a floor shift. I have never liked the mechanics involved with column shift automatics. I will probably go with a Lokar floor shift model.
I doubt you'll find a drop in column wihtout the shifter on it, unless one from a 1 ton Chevy truck of early 50s vintage will fit (they had four speed floor shifts). Unless the column shifter is worn out, it will work fine. What I've done in the past is clamp the two shift levers together (mine were close enough I used a pair of fender washers on a bolt between the levers) then connect the shift rod for an auto to the lever that aligns best with the quadrant on the column. You could just use one lever or the other, but have to remember NOT to pull the lever. When you get it out of the groove the lever you have the auto trans hooked to it's not fun getting it back. Clamping them togther fixes that problem -- they both move together all the time. Rod shops have nice aluminum and plastic shift quadrants that stick to the column with an arrow. Stick the arrow to the moving collar, quadrant to fixed part between collar and steering wheel. Easy conversion that looks factory, but it is still on the column.
| pre-65 Chevy rear end info-- anyone knowledgeable? | matt_ramsey | Transmission - Rearend | 6 | 03-29-2005 09:00 AM |
| 54 chevy car rear end choices | lordkevork | Transmission - Rearend | 6 | 01-20-2005 11:57 AM |
| Help with '57 Chevy Rear End | 57Chevyman | Transmission - Rearend | 15 | 12-25-2003 09:43 PM |
| Rear end swap problems | datsun dale | Transmission - Rearend | 1 | 12-17-2002 10:50 PM |
| transmission rear end for 65 chevy truck | shortwide65 | Transmission - Rearend | 0 | 05-28-2002 08:37 AM |
