Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 54 Desoto Firedome Wiring Confusion
Old 07-06-2013, 05:41 PM
LATECH's Avatar
LATECH LATECH is offline
Test the switch. Plain and simple. Put an ohmeter across the terminals.
See what it does. If it conducts while the trans is in reverse, then it is a reverse light switch.
If it conducts only in park or nuetral, then its a nuetral safety.
That will help you narrow down the wire question as well.
Hook an ohmeter to the solenoid energize wire on the starter , and probe the wires at the switch in question. If you have continuity on one wire, then you have the wire from a nuetral switch.The other wire will be from the key while in the cranking position. Simple logic...just think about it for a few minutes, and use an ohmeter.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
hduff (07-06-2013)
