54 dodge master cylinder modification - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2006, 09:15 AM
Magnus_Jager's Avatar
Tow Chainer
Last wiki edit: Rebuilding an early Hemi engine
Last journal entry: cruise pics
Wiki Edits: 2
I have a 54 dodge with the original brake system. All the components are new, or like new. Wheel cylinders master cylinder shoes lines etc. The problem is they are original style with the one piece cast master cylinder under the floor.
Basically the master is one cast piece. It has a threaded filler on top and the reservoir is cast into the unit. It has one line out the back of the unit and a rod into the front that actuates the cylinder.
I have seen a relocation unit for the old vettes with under floor brakes.
http://www.ecihotrodbrakes.com/remote_fill_master_cylinder.html'
What I think I can do with this unit is drill and tap npt hole into the side of the reservoir, add a flange fitting and hook a line to the bottom of a higher mounted tank.
Then drill and tap another line off the threaded filler on the top, connected to the top, or high on the side of the remote tank to allow air to escape back to the remote tank.
This way I should not have to worry about air bubbles keeping the lower tank from filling.
Old 01-04-2006, 09:30 AM
powerrodsmike's Avatar
Wiki Edits: 161
Skip the drilled and tapped hole in the side of the M/C. You don't need it. Use 5/16 line to go to the remote resovoir and the air will rise up naturally. Be sure to plug the vent hole in the threaded cap or it will become a drain for the remote res.
BE different....ACT normal.
Old 01-04-2006, 09:38 AM
Tow Chainer
Wiki Edits: 2
I just found this on ebay, where I going a little more rat on this I think this would be my answer. I see what your saying on the air clearing. I am a bit of an over engineer when it comes to things. Belt and suspenders type.
http://cgi.ebay.com/ebaymotors/Aircr...QQcmdZViewItem
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 04:42 PM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 09:18 PM
54 dodge brakes Magnus_Jager Suspension - Brakes - Steering 2 11-16-2003 02:40 PM
Help with continuing master cylinder problem chris57 Suspension - Brakes - Steering 3 09-30-2003 03:35 PM
Help! Going Nuts! Mysterious Master Cylinder delstretcho Suspension - Brakes - Steering 6 03-11-2003 06:54 AM
