54 F350 4 speed manual, will it work with a SBC? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2011, 10:02 PM
fast68's Avatar
likes chevy trucks & boobies
if i were to yank out the original 239 ford v-8 engine out of the 54 dually F350 i have and put in a SBC engine would a 72 older truck cast iron chevy bellhousing bolt to the 1954 ford 4 speed tranny and would everything else be ok as far as input shaft and clutch and all that?
which year make mode parts would i need to use as far as clutch disc and pressure plate and TO bearing go?
would a chevy TO bearing work on the ford input shaft?
could i use a ford clutch disc of the splines are not the same as a chevy? 10 spline? or how many splines are on a ford 4 speed in 1954?
hopefully the ford trucks didnt usde the bellhousing mounted clutch linkage pivot ball stud?
if so then im gonna be screwed then and have to go with a chevy tranny and custom clutch linkage then...
thanks
Old 07-26-2011, 02:00 AM
JeffB's Avatar
Getting that combo to work would end up being a nightmare for you,if you are retaining the F-350 rear end it would be much better to go with a 700R4 transmission,universal mounts can be had from Trans-Dapt or Speedway Motors to make the swap.
Old 07-26-2011, 07:53 AM
Wiki Edits: 27
what do you want to make.
If it's going to be a farm truck and you need a granny gear, the larger chevy truck bell housing with enough space for a 12 in or larger clutch will bolt up to a lot of truck transmissions, I know one guy who put a sbc in his 2 ton international . just mixed up parts, chevy truck bell housing bolted up to the Int trans,.. If you are wanting a highway truck, a late GM OD auto would be better.
Old 07-26-2011, 08:01 AM
Wiki Edits: 27
engine swap.
I think the ford truck would be 1 3/8 I am not sure, You use the disc and throwout bearing to match the trans, several sizes are available, depending on flywheel hole pattern. The guy with the international first used a car clutch and It didn't last,, Our SBC into the jeep used a car clutch. the last swap was to 78 Blazer Trans and tranfer case, rear end , front disc axles. the Blazer clutch was larger .
What manual trans will work on my 283 ? Mike Woodman Transmission - Rearend 9 04-11-2011 07:16 AM
4-speed manual trans i.d red100truckneb Transmission - Rearend 0 11-09-2007 10:01 PM
4-speed manual i.d babygene41042 Transmission - Rearend 3 01-13-2005 10:50 PM
Manual 4 speed something ManfromKy Transmission - Rearend 7 04-09-2004 01:16 AM
4 speed manual APACHEMAN Transmission - Rearend 5 07-22-2003 03:11 AM
