54 ford,302 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2011, 03:45 PM
54 ford,302
,,Hows it goin fellow rodders,well here's a little about my project I have a 54 ford mainline ,that is runing a ,302 v8 with a c4 trany. Im having trouble with a rocker arm stud that broke ,I wana know how to remove it ,and how to determine if it's a srew in stud or if it is pressed in .
Old 12-27-2011, 10:44 PM
Hotrod Hirning's Avatar
New Member
Stud
If the stud is broken flush with the head surface you need to use an easy out tool. If a stub is above thee head surface you could thread and double nut it for removal. If the 302 was built before 1990 the stud is pressed in, only 289 hi-perf heads had screw in studs.
Old 12-28-2011, 02:14 AM
JeffB's Avatar
Click on this:http://www.mre-books.com/interchange/interchange5.html at the bottom of the article you will see a Hi-Po head, notice the jam nut at the bottom of the stud? If no jam nut it's pressed in,to replace the stud with the head on the car may be a little tricky so the best option is remove the head and take it to a machine shop or buy a used head with the same code stamping which may be cheaper than the shop rate.Or maybe this would be a better option to pick up a power increase:http://craigzoom.com/index.php?query...craigslist.org GT40's with a fresh valve job for $330 is a pretty good deal.
1948 Ford stock engine/tranny with Ford 9" rear end beek15853 Transmission - Rearend 5 04-04-2012 08:56 PM
1934 Ford transmission with1948 Ford truck engine clutch questions ppetrano Transmission - Rearend 1 05-20-2011 12:02 PM
35 Ford Coupe front clip on 35 Ford truck 35hotrodtodd General Rodding Tech 8 12-27-2007 03:00 PM
1932 Ford rims Kelsey Hayes or Ford motor Co. alf51chevy Suspension - Brakes - Steering 2 09-12-2005 09:14 PM
Ford Racing Visteon Ring & Pinion, 9" Ford ??? acr Transmission - Rearend 2 07-23-2004 10:17 AM
