Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 54 International R-110 Transmission
Old 10-03-2012, 06:59 AM
timothale timothale is offline
Wiki Edits: 27
truck transmissions.
Farm size trucks used universal transmissions, a friend put a SBC in his dually and used the Chevy truck bellhousing and it bolted up to the International trans. if you used a international truck bell housing you might be able to use a truck trans , granny first gear not desirable unless you are going to be climbing hills, pulling out logs,
