Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ~54" wide, 8.5" 10 bolt rear end question
Old 10-05-2009, 06:14 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
The S-series 8.5's were only available with the ZR2 off road package, and were actually 5 inches WIDER overall than the standard S-series 7.5/7.625 axles.
You would be better off getting an 8.8 Ford Explorer rear (98 and later had disc brakes), and were minimally wider than the 7.5/7.625.
Offset wheels can make up the difference and make it look just like stock in whatever you put it in.
