~54" wide, 8.5" 10 bolt rear end question
Hello
I'm looking to add an ARB Air Locker or Eaton E-Locker to an ice racer. The idea is having full traction on both wheels where traction permits, yet have a fully open differential in the turns. I'm looking for a rear end roughly 54" wide. I found out that the 1984 Chevy S10 rear is 54" but I'm not sure that one came with the 8.5" RG. Can anyone help me with some applications so I can go to the Junk yard without having to remove the differential cover off of every diff that is skinny enough for me? Thanks Herbie |
gfghgfhfghggbghgfhgfhgd
The S-series 8.5's were only available with the ZR2 off road package, and were actually 5 inches WIDER overall than the standard S-series 7.5/7.625 axles.
You would be better off getting an 8.8 Ford Explorer rear (98 and later had disc brakes), and were minimally wider than the 7.5/7.625. Offset wheels can make up the difference and make it look just like stock in whatever you put it in. |
| All times are GMT -6. The time now is 12:08 PM. |
