~54" wide, 8.5" 10 bolt rear end question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2009, 10:10 AM
Hello
I'm looking to add an ARB Air Locker or Eaton E-Locker to an ice racer.
The idea is having full traction on both wheels where traction permits, yet have a fully open differential in the turns.
I'm looking for a rear end roughly 54" wide. I found out that the 1984 Chevy S10 rear is 54" but I'm not sure that one came with the 8.5" RG. Can anyone help me with some applications so I can go to the Junk yard without having to remove the differential cover off of every diff that is skinny enough for me?
Thanks
Herbie
Old 10-05-2009, 12:55 PM
fast68's Avatar
likes chevy trucks & boobies
gfghgfhfghggbghgfhgfhgd
Old 10-05-2009, 05:14 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
The S-series 8.5's were only available with the ZR2 off road package, and were actually 5 inches WIDER overall than the standard S-series 7.5/7.625 axles.
You would be better off getting an 8.8 Ford Explorer rear (98 and later had disc brakes), and were minimally wider than the 7.5/7.625.
Offset wheels can make up the difference and make it look just like stock in whatever you put it in.
Old 10-06-2009, 06:31 AM
Thanks M&M. I'm starting to think that width won't be a problem. I checked the ice race rules, and I'm allowed to flare the wheel wells 4" each side. So now I think all I need to do is source an axle that I can get an ARB locker in.
Gear swap in 10 bolt rear end 1987 Cutlass pena0724 Transmission - Rearend 2 07-16-2009 10:27 PM
Chevy 10 bolt front end question Magikal Transmission - Rearend 1 12-09-2007 01:00 PM
10 bolt chevy rear end question powerrodsmike Transmission - Rearend 3 09-15-2007 10:00 PM
Can rear end gears be swapped at home? (8.5" 10 bolt) Warrant Transmission - Rearend 6 09-22-2006 09:55 AM
10 bolt 8.5" rear end - RARE? jvenice Transmission - Rearend 3 10-26-2002 12:27 PM
