http://www.hotrodders.com/forum/atta...1&d=1361249043
This pic help any? Click a couple of times to enlarge. |
| The Following User Says Thank You to painted jester For This Useful Post: | ||
carolinacustoms (02-18-2013) | ||
Kelly |
But those I did came out good no one could tell they weren't already there.Jester |
carolinacustoms (02-19-2013) | ||
There you go Jester, perfect! Making patterns is so overlooked, tape, paper, metal, making a pattern is some of the best time spent on a project.
Another way I transfer the info is to simply stick the tape that the pattern was made from and using a razor knife cut the tape on the lines, leaving the pattern exposed on the metal below to make another nice line with a sharp Sharpie. Remove the tape and there you go. Brian |
you can make those holes that look like pills very easily. Just take your template and drill two small holes at each end. Maybe a 1/8" bit will do. Then you take a very small cut off wheel that comes with those plug in dremel tools and slice it between the drill holes. Then file to perfection. When you make your template you use body lines, edges, door handle holes, whatever you can think of as a reference to help you align it to the other side.
Thanks Brian!!
Kelly I also painted the steel under the pattern flat white !! Its easier on the eyes LOL And you can see the outline better when filing!![]() Jester |
Thanks for the tips guys. I used the old quarter for a template, just cut out the piece with the holes and since the new quarter is ecoat black I used some chev orange to paint over the template which have me a perfect orange pattern under to go by. I guess I need to dig out the dremel. Thanks again
Kelly |
That can work Kelly for putting the holes properly to each other, but in putting the holes on the proper place on the panel it isn't so cut and dry. So make some templates as Henry described off a body line or hole or edge so you make sure you are putting them in the exactly same location. Double checking is always a good idea.
Brian |
Kelly |
check it with measuring from clear reference points on both the cut out one and the new one. There may be a slight difference cause the thickness of the metal as opposed to a paper template laying on top of it.
What's good about templates for moulding holes with tape/welding paper is you know the number of holes in correlation with each other will stay true as long as you cut them out cleanly and tightly tape/welding paper it down. So once your holes are cut out the only real concern is making sure the 1st and last holes are matching their measurements and you're hitting your reference points(marked bodyline/door handle hole/ edge of panel) and everything else should be fine. |
| Quarter and Bumper question | dboyett81 | Body - Exterior | 7 | 05-15-2011 07:30 PM |
| 54 210 | 54 chevy210 | Body - Exterior | 1 | 01-08-2009 08:43 AM |
| Learned a lot from HBB but a question on repair of quarter flange | Ripped | Body - Exterior | 6 | 10-19-2006 07:18 AM |
| 57 Chevy 210 trim question | MustangMatty | Body - Exterior | 1 | 10-04-2006 03:40 PM |
| Quarter miles question | Ratoflic | Hotrodding Basics | 15 | 10-05-2005 08:13 PM |
