'55-'59 Chevy brake light switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2011, 02:39 PM
Irelands child's Avatar
Just 'cause I want better reliability, I decided to change the line pressure brake light switch to the old '55-'59 Chevy lever arm mechanical style. I got the switch home, but before I crawled under the car decided to check operation. It has continuity with the lever at rest. Is this correct? Does it have to be depressed/operated for correct operation? Or - do I need to return it for another? It was even stamped Made in USA
Dave W
Irelands child
Old 01-14-2011, 02:44 PM
poncho62's Avatar
Wiki Edits: 5
Yes...thats right....It attaches to the pedal, so when you push it, it comes to the rest position......You have to make a bracket that holds the button in when your foot is off the brake.
If youn think about it, thats the only way to do it as the pedal is braking at different positions
Old 01-14-2011, 05:52 PM
Yep - thought so - went back with my DVM and "proved it" to myself as well. Now - all I have to do is get my creaky bones under the car and do the installation. Thanks
Dave W
Irelands child
Old 01-14-2011, 06:53 PM
EOD Guy's Avatar
might think about attaching it to the steering column/mount so that when the pedal is in the up (off) position it holds the switch open and when you depress the brake pedal it allows the switch to come to the rest (on) position....... let off the switch is depressed etc.....
Old 01-14-2011, 07:00 PM
RODDER18's Avatar
Isn't the master cylinder mounted to the frame? If so the pedal would come up through the floor.
Old 01-14-2011, 07:13 PM
The MC is on the frame on a TCI chassis. I have to 'dream up' a bracket and lengthen a couple wires. No big thing except too many hours laying on my back
Dave W
Irelands child
Brake light switch ericrcan Electrical 26 09-22-2010 02:15 PM
BRAKE LIGHT SWITCH ( I tried everything ) Blackbob Electrical 1 11-30-2008 01:42 PM
Brake light switch? cabrio Electrical 14 05-04-2007 07:08 PM
Brake light switch? 39chevy Electrical 4 02-19-2007 04:31 PM
Brake Light Switch 66chevy2ss Electrical 9 09-24-2002 12:50 PM
