Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 08-17-2008, 06:29 PM
rustbusterjack rustbusterjack is offline
55-59 Chevy truck
what (auto-truck)gas tank will fit in the frame and allow the exhaust pipes to pass? Thanks Jack, gto1buf@yahoo.com, cell # 920-279-6504
Old 08-19-2008, 06:54 AM
Houston54's Avatar
Houston54 Houston54 is offline
re: 55-59 Chevy truck
The 16 gallon tank from a 67-68 Mustang would fit. It is not too wide but you will have to fabricate a support frame to catch the mounting flange. You would also have to address the sending unit ohm range difference between GM and Ford fuel gauges. Solution there is to use an aftermarket sending unit that you would mount to the top of the tank prior to installing. You could use the original pickup/sending unit for the fuel line. You can find this tank listed on ebay as a kit sometimes. The dimensions of the tank is usually included.
I was using a 67-69 Camaro tank in my 54 but just changed it out to a Tanks, Inc. universal tank to get more clearance for my pipes. It is a good option for your application also. Got mine through JPL with free shipping.
Old 08-19-2008, 07:22 AM
Thanks, I will look into this. Maybe I can route a filler opening behind the license plate.
Old 08-20-2008, 09:58 AM
bet on black's Avatar
bet on black bet on black is offline
hotrodder 4 life
i am going with a blazer tank like this for my 59:
http://cgi.ebay.com/ebaymotors/Blaz...emZ200244212739
it is 31 gallons and fits between the frame rails behind the axle (where the spare tire is)
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "55-59 Chevy truck"
55 to 59 chevy truck owners DOUBLEDICK Hotrodders' Lounge 1104 Yesterday 06:33 PM
55 chevy truck rear end swap Wildman Transmission - Rearend 8 06-11-2007 07:16 PM
Mustang 2 Front end on a 55 Chevy truck? Slickriffs Suspension - Brakes - Steering 2 05-16-2006 08:58 AM
Looking at project cars, 42 chevy, 55 desoto, 59 ford truck among others Wmarden Hotrodders' Lounge 8 02-08-2005 05:19 PM
nova subframe on a 59 chevy truck bet on black Suspension - Brakes - Steering 3 01-27-2005 08:48 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
