55-59 Chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2008, 06:29 PM
55-59 Chevy truck
what (auto-truck)gas tank will fit in the frame and allow the exhaust pipes to pass? Thanks Jack, gto1buf@yahoo.com, cell # 920-279-6504
Old 08-19-2008, 06:54 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
The 16 gallon tank from a 67-68 Mustang would fit. It is not too wide but you will have to fabricate a support frame to catch the mounting flange. You would also have to address the sending unit ohm range difference between GM and Ford fuel gauges. Solution there is to use an aftermarket sending unit that you would mount to the top of the tank prior to installing. You could use the original pickup/sending unit for the fuel line. You can find this tank listed on ebay as a kit sometimes. The dimensions of the tank is usually included.
I was using a 67-69 Camaro tank in my 54 but just changed it out to a Tanks, Inc. universal tank to get more clearance for my pipes. It is a good option for your application also. Got mine through JPL with free shipping.
Old 08-19-2008, 07:22 AM
Thanks, I will look into this. Maybe I can route a filler opening behind the license plate.
Old 08-20-2008, 09:58 AM
bet on black's Avatar
hotrodder 4 life
i am going with a blazer tank like this for my 59:
http://cgi.ebay.com/ebaymotors/Blaze...mZ200244212739
it is 31 gallons and fits between the frame rails behind the axle (where the spare tire is)
55 to 59 chevy truck owners DOUBLEDICK Hotrodders' Lounge 2931 12-08-2016 01:15 PM
Mustang 2 Front end on a 55 Chevy truck? Slickriffs Suspension - Brakes - Steering 14 11-10-2010 06:10 PM
55 chevy truck rear end swap Wildman Transmission - Rearend 8 06-11-2007 07:16 PM
Looking at project cars, 42 chevy, 55 desoto, 59 ford truck among others Wmarden Hotrodders' Lounge 8 02-08-2005 05:19 PM
nova subframe on a 59 chevy truck bet on black Suspension - Brakes - Steering 3 01-27-2005 08:48 PM
