We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #61
Old 10-30-2009, 09:39 AM
dragfrog23 dragfrog23 is offline
truck bed
I'm gonna use a sheet of plate steel and not diamond plate. I already have a frame built to lay it on, so I'll only have to do the perimeter. I won't be doing wheel tubs like the two of you have. I can adjust my wheel offset where my tires will fit in the fender. The S10 bed floor is a cool idea. Thanks
Old 11-06-2009, 10:47 AM
fasteddy51 fasteddy51 is offline
Kurt
I am trying to remember what tilt steering column you used for your truck. If I remember, it was from a G-body (Monte, Malibu, Cutlass?) I can't find the picture that you had that showed it from under the dash. My 1978 Truck column is too long. For some reason I thought I could use it. Thanks!
Old 11-06-2009, 08:16 PM
RODDER18's Avatar
RODDER18 RODDER18 is online now
Ed, It is from a 78 lesabre. It fits well but does have the bump out on the side for the tilt and turn signal. I am still looking for one that does not have the bump out. Also when I installed it I had to remove part of the dash support to get it up under the dash. Hope this helps.
Kurt
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "'55-59' Chevy Truck Frame Clip w/G-Body?"
Takin 84 chevy truck to body shop Lthompson Body - Exterior 7 11-19-2007 03:30 PM
55 chevy body swapped to an S10 frame. 55shoebox Body - Exterior 4 09-10-2007 06:07 PM
55 chevy frame? runn141 General Rodding Tech 1 08-08-2007 07:44 PM
Need some help about my 1967 chevy truck frame 67Chevy_c10 Body - Exterior 4 03-17-2006 05:56 PM
55 chevy frame in a sedan delivery? 55delivery Body - Exterior 2 03-16-2003 06:43 PM
